Thread: 180* Tstat Tune Help
Results 1 to 5 of 5
  1. #1 180* Tstat Tune Help
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Hey guys, i installed my 180 tstat about 1 week ago after my engine swap and i am wondering how do i change my settings in my bin to a 180 tstat and where do i go to change it? Thank you.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: 180* Tstat Tune Help
    Outer Space
    No changes necessary
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: 180* Tstat Tune Help
    Quote Originally Posted by Lawngoose View Post
    fer serious, goose?
    you need to change the fan turn on temp to be lower so it actually turns the fans on when you want them to to make the thermostat worthwhile. if you do not do this the car will run at stock temps because the fans wont turn on until stock temps, regardless of what thermostat you have in it and when it does and does not open.
  4. #4 Re: 180* Tstat Tune Help
    Outer Space
    fer serious, goose?
    I assume he had a can tune, your right about the fans though.
  5. #5 Re: 180* Tstat Tune Help
    SE Level Member Phantom's Avatar
    Independence KY
    The fan turn on temp will only make a difference at slow speeds or idling when cruising it will not come on so the lower temp T-stat will still have an effect.
  1. school me on my 180* Tstat
    By mxthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 04:09 PM
  2. 180 tstat
    By bballa0740 in forum General Tech Discussion
    Last Post: 10-03-2009, 08:31 AM
  3. Drilling a Tstat????
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 06:49 PM
  4. 180 tstat question
    By superv6 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:25 PM
  5. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
