Thread: 180 tstat
Results 1 to 19 of 19
  1. #1 180 tstat
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    is there a guide on how to do it best if not can anyone explain?
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  2. #2 Re: 180 tstat
    Charles City, IA
    Take off thermostat housing remove old t-stat install new one. Also note
    Tech Tips post your shortcut ideas, things that make a job easier. Please use the How To section to post up full details on modifications/repair
    SMGPFC Two Nipple General
  3. #3 Re: 180 tstat
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    U will need a housing gasket and stat seal. Remove the housing bolts, replace everything and reinstall housing. Pretty easy
  4. #4 Re: 180 tstat
    Charles City, IA
    There is no gasket on the housing.
  5. #5 Re: 180 tstat
    X2...no housing gasket...just a T-Stat o-ring.
  6. #6 Re: 180 tstat
    GTX Level Member cerick08GP's Avatar
    What he said ^^^
    I just went to a 180F on my 08GP, no housing gasket.
  7. #7 Re: 180 tstat
    GEORGIA
    Mine has a housing gasket. I work at advance and they sell a housing gasket 4 it, also the stat seal. I removed an old 1 of it when i replaced my stat 2 a 180.
  8. #8 Re: 180 tstat
    GEORGIA
    U said it 08. I have a 98. I can take a pic of the gasket if it helps. Is bballa0740 replacing a stat on an 08? If thats the case, i didnt know. I just know my 98 gtp has a housing gasket.
  9. #9 Re: 180 tstat
    Ohio
    97-03 do not have housing gaskets they are available like said above though. Not even gxps have housing gaskets.
    00 GTP demodded and forsale
  10. #10 Re: 180 tstat
    GEORGIA
    o ok. well since it was available i put 1 on. better safe than sorry.
  11. #11 Re: 180 tstat
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    my 98 had on too on it. mechanic told me i shouldnt need the gasket but he was wrong. I turned on my car on be4 i knew it anti freeze was going everywhere lol...i had heard that only certain years need them but i dont remember what ones. all i know is the 98s DO need one
  12. #12 Re: 180 tstat
    GEORGIA
    well glad i replaced it then.
  13. #13 Re: 180 tstat
    i had a gasket, but couldnt find anyone that sold it. even the dealer. so i put my t-stat back in with a new o-ring and it sealed up fine.
  14. #14 Re: 180 tstat
    GEORGIA
    Advance auto sells them. Thats where i got mine.
  15. #15 Re: 180 tstat
    im not sure as to why the OP needs a 180* thermostat either since his mods arent really anything that would require cooler coolant temperatures.
  16. #16 Re: 180 tstat
    Guam
    Just did my 99 and it did not have a gasket, just the T-state O-ring seal.
    My car also uses the supercharged Fuel Pressure regulator part, so go figure.
    Discovered this after buying the non-sup charged, getting home and seeing that it would not fit. Returned it, got the supe charged one and it fit and was correct.
  17. #17 Re: 180 tstat
    SE Level Member mtz956's Avatar
    browntown
    hey do u think not having a thermostat would affect me? i took mine out .
  18. #18 Re: 180 tstat
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by mtz956 View Post
    02 GTP with mods 05 GP for DD
  19. #19 Re: 180 tstat
    Wow...that's pointless.
  1. 180 tstat question
    By superv6 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:25 PM
  2. 180 tstat drilled or not drilled?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 04:04 PM
  3. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
