In my opinion you would want to go ahead and tune for VE especially if you are putting in a cam because that will change your numbers from a stock cam. Even if it is only used when the maf fails i wouldn't want to be at the track at 6000 rpm when the maf decides to give out and the computer is only thinking your getting a smaller amount of air and your fueling gets all screwed up, possible to cause damage.
