I googled the size and got 31 from 2 pages...
I called GM, they were no help
if you mis calculated the injectors to a higher rate you shouldnt be pulling a lean condition code
I thought 04+ were 36 lbs,
Ed morad lists them as 36, from his listing:
This sale is for a set of 6 good used factory 36 Lbs. flow fuel injectors. These will fit GM 3.8 / 3800 series III L32 supercharged engines.
The part number is 12574393. These are the blue / gray in color.
