Thread: SES Code after injector Upgrade
Results 1 to 13 of 13
FastKatt SES Code after injector... 05-02-2008, 06:10 PM
FastKatt Re: SES Code after injector... 05-02-2008, 08:32 PM
Sabrewings Re: SES Code after injector... 05-02-2008, 09:18 PM
FastKatt Re: SES Code after injector... 05-02-2008, 09:26 PM
Reptile Re: SES Code after injector... 05-05-2008, 11:19 AM
FastKatt Re: SES Code after injector... 05-05-2008, 04:38 PM
Guest Re: SES Code after injector... 05-13-2008, 08:56 AM
Guest Re: SES Code after injector... 05-13-2008, 08:58 AM
02BlueGT Re: SES Code after injector... 05-13-2008, 09:54 AM
02BlueGT Re: SES Code after injector... 05-13-2008, 09:57 AM
Guest Re: SES Code after injector... 05-13-2008, 11:11 AM
FastKatt Re: SES Code after injector... 05-13-2008, 07:03 PM
FastKatt Re: SES Code after injector... 05-13-2008, 08:27 PM
  1. #1 SES Code after injector Upgrade
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    I got a P0171 code after installing 39# injectors
    I changed the IFR based on 31/39=.794871
    So, Table/0.795=NewTable
    Am I wrong?
    Did I have 36# injectors?
    Is it just my trims are that far out of whack?
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  2. #2 Re: SES Code after injector Upgrade
    Feb 2008
    Rkrd, IL
    No one?
  3. #3 Re: SES Code after injector Upgrade
    Barksdale AFB, LA
    Quote Originally Posted by FastKatt View Post
    No one?
    It's only been a couple hours, gotta give it time.
    2009 Subaru Impreza WRX STI
  4. #4 Re: SES Code after injector Upgrade
    Feb 2008
    Rkrd, IL
    That was a TTT post, I hit the 2nd page
  5. #5 Re: SES Code after injector Upgrade
    Bastard Reptile's Avatar
    Kansas City, MO
    I thought that they were 36lb/hr.
    But honestly I can't say for certain....I'll look on the pt forums and see what comes up
  6. #6 Re: SES Code after injector Upgrade
    Feb 2008
    Rkrd, IL
    I googled the size and got 31 from 2 pages...
    I called GM, they were no help
  7. #7 Re: SES Code after injector Upgrade
    TDCRacing
    Guest
    do a maf tune and see if it goes away....reset the fuel trims
  8. #8 Re: SES Code after injector Upgrade
    TDCRacing
    Guest
    if you mis calculated the injectors to a higher rate you shouldnt be pulling a lean condition code
  9. #9 Re: SES Code after injector Upgrade
    Hoffman/Schaumburg, IL
    I thought 04+ were 36 lbs,
    Ed morad lists them as 36, from his listing:
    This sale is for a set of 6 good used factory 36 Lbs. flow fuel injectors. These will fit GM 3.8 / 3800 series III L32 supercharged engines.
    The part number is 12574393. These are the blue / gray in color.
  10. #10 Re: SES Code after injector Upgrade
    Quote Originally Posted by TDCRacing View Post
    I think it could, the computer is expecting more fuel than it is getting, the injector pulse is shorter the higer the flow injector(to get the same fuel) so a injector that flows less than what the computer is set for could cause a lean condtion
  11. #11 Re: SES Code after injector Upgrade
    TDCRacing
    Guest
    Quote Originally Posted by 02BlueGT View Post
    Sorry I read that backwards....I was thinking that the injector that was put in was flowing more than what the pcm was set for...sorry
  12. #12 Re: SES Code after injector Upgrade
    Feb 2008
    Rkrd, IL
    Well, I added 10% to the IFR Table
    Trims were closer, did 1 MAF tune, trims look alot better
    I'm about to update the MAF for the 2nd time tonight
    We'll see where it goes
  13. #13 Re: SES Code after injector Upgrade
    Feb 2008
    Rkrd, IL
    Okay,...
    I took these threads to heart, and talked to a few people
    I'm redoing my IFR Table with math for 36# vs. 39#
    So, 92.3% change
    Also, I back-up to my last MAF Table b4 I changed the FIs
    We'll see where this leads me
  1. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  2. How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 06-05-2012, 11:59 PM
  3. new owner and need upgrade tips!!!!!
    By big daddy 67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2008, 12:27 AM
  4. Upgrade Recomendations
    By Risinnfallen in forum General Tech Discussion
    Last Post: 04-19-2008, 03:28 AM
  5. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
