Check your coolant temp sensor, there are two side, so the dash gauge may show ok, but the PCM wont see it, you can check this with your LS1M..... Also, may have fugged something in the o2 sensor circuit in the pcm... and look for a ground issue with your gauge, when your at WOT the engine moves alittle, and this my be causing the spike to 100psi
