Thread: stuck in open loop and LTFTs pegged at 0.0%
Results 1 to 9 of 9
  1. #1 Re: stuck in open loop and LTFTs pegged at 0.0%
    thanks for the suggestion o2bluegt however i guess resoldering the o2 sensor didnt do a difference cause the P0134 code came back which is something like No activity frmo B1S1. im gonna go to pep boys/advanced auto and get another ac delco o2 sensor >.<
  2. #2 Re: stuck in open loop and LTFTs pegged at 0.0%
    TDCRacing
    Guest
    not to state the obviouse but did you solder the correct wires back? in other words did you switch the 2 up by accident??
  3. #3 Re: stuck in open loop and LTFTs pegged at 0.0%
    Barksdale AFB, LA
    The sensor itself may have been damaged when the harness was burnt. Probably best to just replace the whole piece.
    2009 Subaru Impreza WRX STI
  4. #4 Re: stuck in open loop and LTFTs pegged at 0.0%
    Hoffman/Schaumburg, IL
    ^^^ good point, if the heater side shorted to the sensor side, I imagine it would destroy the unit pretty quick
  5. #5 Re: stuck in open loop and LTFTs pegged at 0.0%
    TDCRacing
    Guest
    A buddy of mine just had that happen to him (wire melting on the header) and all he did was just solder them back and it was good...guess he is an exceptionn to the rule lol or just got lucky
  1. 04+ HUD is stuck...
    By PonchoDvr4Lfe in forum General Tech Discussion
    Last Post: 02-22-2012, 01:55 PM
  2. Key stuck and Dead Car
    By joe_cool in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2010, 04:13 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. open air filter in engine bay
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2008, 04:21 PM
