got hptuners and a 2000 gtp...question is what can keep a gtp from going into pe mode. about 10% that i floor the pedal my tranny downshifts, i accelerate, but i dont get that kick. im assuming im not entering pe mode. so what causes this since i have no knock and the car is running great. also what is all the other charts under pe and accel enrich in tptuners? i understand the afr tables that determine afr per tps and the hot enable but the rest is over my head. do the rest of the tables need adjusted and will this solve a pe hot problem?
