Thread: '98-'00 PCM in my '97
Results 1 to 5 of 5
  1. #1 '98-'00 PCM in my '97
    Feb 2008
    I've been trying to figure out if it would be possible to use a newer PCM in my '97 GTP (I may have even asked this same question before). I believe the pin-out and connectors are the same. I'd like to have the slightly larger tables that are available with the newer OS's, as well as the physically smaller PCM. AFIK all the engine electronics are wired the same. If I attempt this, what problems might I run into other than wasting money on a PCM I can't use?
  2. #2 Re: '98-'00 PCM in my '97
    Monroe Twp, NJ
    Pin out conenctions are not the same. You lose various functions in the car, one such as ABS :P
  3. #3 Re: '98-'00 PCM in my '97
    Outer Space
    if you need another 97 PCM, I have one that I am not using.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: '98-'00 PCM in my '97
    SE Level Member John Sheppard's Avatar
    Warner Robins, GA
    Wiring harness, replace it all and you've got yourself a 98-02
  5. #5 Re: '98-'00 PCM in my '97
    Feb 2008
    Darn. ABS on my '97 doesn't work for crap anyway, so that wouldn't be a huge loss... I don't need another PCM. I'm just wondering.
