Thread: Why cant I see parameters
Results 1 to 12 of 12
  1. #1 Re: Why cant I see parameters
    SE Level Member deangtp's Avatar
    Kansas City, MO
    Its a 2000 Pontiac Grand Prix GTP. It has a 2004 GT block, XP cam, 105's, dbl rlr, P&P heads/LIM/Gen V. I am using the Powertuner via the OBD2 port.
  2. #2 Re: Why cant I see parameters
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I have had that same problem with my pt a couple times too. I can't remember what I all did though. I know if you have too many of the little windows open at one time it screws things up. I am talking about the little parameter windows. Have you tried closing all the parameter windows and starting over?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: Why cant I see parameters
    PA
    Quote Originally Posted by Andrew_99GTP View Post
    Yup, this was my thought. I was trying to pinpoint a misfire. So I had all of my regular PIDs. Then added the misfire ones, and the misfire histories. Ended up being too much and wouldn't scan anything. Got rid of the PIDs I didn't need, and all was well again. Stumped me for a bit though.
    2001 GSE
  4. #4 Re: Why cant I see parameters
    New Salem, ND
    I was trying to do a case learn with too many windows open, had me not only stumped but very
  5. #5 Re: Why cant I see parameters
    Kansas City, MO
    I dont get it. When you go to your car, start it. Go to PT and go to scantool. Click on connect and you see the dropdown of viewable parameters. There is no 02 reading, there is no boost. You cant even select them with no windows open.
  6. #6 Re: Why cant I see parameters
    New Salem, ND
    Oh I see. Hmm I guess I don't know what to tell you then. Sounds like something is wrong with your pt program.
  7. #7 Re: Why cant I see parameters
    TDCRacing
    Guest
    Do you maybe have to set it up in the user defined pids?
