Thread: what limits boost
Results 1 to 20 of 22
  1. #1 Re: what limits boost
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by deangtp View Post
    Well I am not gonna go posting around my 1.0 BIN file silly. That's a big no no and would put a bunch in many a panty. Lets say, you start your car. Go to the scanning and connect and it gives you the drop down for options you would like to see a gauge for and scan for. In my Transmission options for one file(L36 OSID) It shows shift time, gears, temperature, all kinds of stuff. With the other file(L67 OSID) it will only show me the temperature. Why the limited parameters. Should I try and put in the actual L67 PCM? Would that give me the ability to see the missing parameters? Or are the missing viewable parameters part of the 1.0 thing?
    Sorry I forgot you were using a DHP. Not really interested in that anyhow.
    So you did a full write with the L67 bin? And yes I would use the L67 PCM as well. It's been a while since so I don't rem if there is a difference between the hardware or not.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: what limits boost
    SE Level Member deangtp's Avatar
    Kansas City, MO
    I dont think most people are interested in it either but ya know..(shrugs) I thought about throwing the PCM in there to see if that would allow me to see the parameters. I have only done full writes on this sooo... IDK i guess ill go throw the L67 PCM in there and see what happens. Its free.
  1. Stock L36 + Boost =
    By Sinister Performance in forum General Tech Discussion
    Last Post: 02-22-2008, 11:28 PM
  2. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
  3. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
  4. Picture Limits
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 12-17-2007, 01:26 AM
