Thread: Rough start-up
Results 1 to 7 of 7
  1. #1 Rough start-up
    Feb 2008
    When I start the car the initial start-up is very rough. It starts instantly, like always, but almost immediately drops down to 500-600 RPM and sounds like it's starved for fuel for just a second or two. If I touch the gas while this is happening, it immediately revs and smooths out, then settles down where it should (~800-1000 depending on temp). When at normal idle, my IAC counts are 90-100. I know that I can adjust the start-up correction tables, but I don't know exactly what and by how much to change. The major mods are in my sig.
  2. #2 Re: Rough start-up
    Oct 2008
    Northern Illinois
    Sound like a vac leak to me. This is EXACTLY what mine was doing when I had a huge one.
  3. #3 Re: Rough start-up
    Feb 2008
    No obvious vac leaks to be found... I do have a slight exhaust leak at my #1 at the manifold gasket.
    When I went to leave from lunch today, I had to crank it for a second or so before it would fire off. It smelled strongly of fuel after I got it started. Maybe my start-up is too rich? That's never happened before.
  4. #4 Re: Rough start-up
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    mine does the same exact thing, only this is, when i start it up in the morning it never gives me a problem, only when im going store to store etc. If you find out what it is let me know
  5. #5 Re: Rough start-up
    Feb 2008
    It still does it every once-in-a-while. Mostly when it's cold out and the engine is cool but not completely cold yet.
  6. #6 Re: Rough start-up
    Nov 2009
    centereach, NY
    mines the opposite, when its 10 degrees out it starts right up, but after running it for a while and than shutting it off and than on, it'll sound like its not getting enough gas.
  7. #7 Re: Rough start-up
    Feb 2008
    ^ That's pretty much what I was trying to say. lol
  1. GTP Running rough.. PLEASE HELP!!!
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2009, 08:46 PM
  2. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
  3. Rough Start
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2009, 11:56 AM
  4. Rough Start from stop....????
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 06:56 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
