Thread: Removing/Disabling the Cat Diagnostic Test....
Results 1 to 5 of 5
whitelightnin04MC Removing/Disabling the Cat... 06-12-2009, 06:14 PM
Lawngoose Re: Removing/Disabling the... 06-12-2009, 08:05 PM
whitelightnin04MC Re: Removing/Disabling the... 06-12-2009, 08:12 PM
Lawngoose Re: Removing/Disabling the... 06-13-2009, 12:15 PM
whitelightnin04MC Re: Removing/Disabling the... 06-13-2009, 12:26 PM
  1. #1 Removing/Disabling the Cat Diagnostic Test....
    Oxon Hill, MD
    So I'm having the really rich LTFT issue on my 01 Monte SS. I've got a 3" DP with high flow cat. Can anyone disable the cat test in my bin file if I send it? I have a powrtuner, but it won't do the job.
  2. #2 Re: Removing/Disabling the Cat Diagnostic Test....
    Outer Space
    Put a 00 or earlier PCM file on it via Powrtuner... that should fix it... or unplug rear o2.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Removing/Disabling the Cat Diagnostic Test....
    Oxon Hill, MD
    i Have an 00 bin file since there really isn't an 01 MC SS bin file. The car came with a 00 MC SS bin. I just flashed the car with the stock bin file earlier. I'll go out and see if the pig rich condition comes back. If it does, I'll start looking at fueling problems. I replaced the plugs a couple hundred miles ago. They all looked fine. No sign of one of the cylinders being richer than another. I wonder if it's possible for a 2000 bin file to have the cat test.
  4. #4 Re: Removing/Disabling the Cat Diagnostic Test....
    Outer Space
    From everything I have read its only in 01+ models.
    Have you changed anything with the exhaust or engine? Mine pegged out like that when i had an exhaust leak. If your exhaust is fine, you might have a vac leak.
  5. #5 Re: Removing/Disabling the Cat Diagnostic Test....
    Oxon Hill, MD
    Quote Originally Posted by Lawngoose View Post
    I'll look into it. I've got a SS ceramic coated Plog, ported rear mani, and a 3" R/T downpipe. Everything was on the car when I got it except for the Plog, which I installed myself. I'll make sure everything is tight and get back to you.
    I did flash a 2000 bin file to the car and I did a scan earlier and didn't notice LTFTs going rich.
  1. disabling auto headlights
    By Jakegday in forum General Tech Discussion
    Last Post: 11-15-2008, 01:23 PM
  2. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
  3. I need diagnostic help!! PO502 and PO503 PLEASE
    By GTPOWER in forum General Tech Discussion
    Last Post: 08-01-2008, 07:07 PM
  4. MAF problem - need diagnostic help...
    By Boatman in forum General Tech Discussion
    Last Post: 05-25-2008, 10:21 PM
  5. Disabling the Door Chime?
    By Abrasive in forum General Tech Discussion
    Last Post: 03-01-2008, 03:41 PM
