Thread: shift point
Results 1 to 8 of 8
  1. #1 shift point
    Jan 2009
    connecticut
    I just recieved my second pcm from overkill, due to issues with the first one. My 1-2 shift goes into the red a little bit, it switches at abot 6200rpm, is this normal? Ok for the car?
    K & N cai / 3" downpipe / hi-flow cat / u-bend delete / 180 T-stat / ceramic coated plog & crossover / Overkill pcm / 3.5" pulley / zzp stage 1 TB / auto lite 104's / msd wires / poly mounts / slp front and rear sway bars / bmr trailing arms /
  2. #2 Re: shift point
    Charles City, IA
    That is normal for a tuned pcm. Mine shifts there too.
    SMGPFC Two Nipple General
  3. #3 Re: shift point
    Jan 2009
    connecticut
    Ok good, I was worried because I never seen it go into the redline. thats no bad for the car then?
  4. #4 Re: shift point
    TDCRacing
    Guest
    It's not good for the car. And there is no need to go that high by any means with the mods you have.
  5. #5 Re: shift point
    Jan 2009
    connecticut
    I wonder why Will set them that high then?
  6. #6 Re: shift point
    TDCRacing
    Guest
    Quote Originally Posted by GMPUNK View Post
    Some people think it's just cool to shift that high. When they don't really know what is going on.
  7. #7 Re: shift point
    Jan 2009
    connecticut
    Yeah I'm not exactly happy with it, the first pcm will sent was the cause of that thump I was getting upon take-off, so we aranged it so he would send me a second one, well the second pcm fixed the thump, but now it just seems slow. The shifts are weak, not quick at all. plus it goes over redline. The original (1st) pcm he sent me was a mess, terrible cold idle, the thump everytime i took off really hard, the cooling fans that run after turning off the car never worked. but I must say atleast the "thumping" pcm was faster, idk if it had to do with the shifts or maybe some other adjustment. First pcm I could get 6.3 sec 0-60mph even with the thump and god know what else was wrong with it, the second pcm which is in the car now, everything works with no problems, only problem it just seems slugish in 1st and 2nd and now I can only get a 6.8 sec 0-60 mph. I'm just so disgusted with the whole thing, I don't know what to do, and Will takes a week to answer e-mails, then if I have to send it to him, it will be 2 weeks before I get it back.
  8. #8 Re: shift point
    all off the shelf PCMs will shift that high. youre running out of your powerband by shifting that high. with the stock cam your power is falling off at about 5500 or so.
    find someone local to really tune your car.
  1. Jack Point / Location
    By american_kestrel in forum Off Topic Discussion
    Last Post: 10-01-2017, 01:12 PM
  2. How do you add tap shift to an 06 gt
    By merciero in forum General Tech Discussion
    Last Post: 04-10-2012, 10:28 PM
  3. High beams "point down"
    By palmergg in forum General Tech Discussion
    Last Post: 10-21-2008, 01:13 PM
  4. At what point do I need to switch to premium
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2008, 11:26 AM
  5. shift kit
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 06:25 PM
