Thread: WOT Shift Points...RPM/MPH
Results 1 to 15 of 15
  1. #1 Re: WOT Shift Points...RPM/MPH
    GT Level Member japslpr's Avatar
    VA Beach
    Quote Originally Posted by Zef_66 View Post
    At WOT, the PCM uses the RPM shift points. At less than WOT, the PCM uses the MPH shift points.
    Awesome. That makes it pretty easy. So I can now just scan and start with the WOT RPM shift point first and adjust the MPH after the scan to get it close.
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  2. #2 Re: WOT Shift Points...RPM/MPH
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    It has been mentioned before, but as I it understood both conditions have to be met. Here is a shift verus MPH based on gearing spreadsheet from Jim at easyperformance...This was pretty close based on the tune Trannyman did. Scanning confirmed as does the tables in the PCM.
    WOT Shift Points...RPM/MPH Attached Files
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: WOT Shift Points...RPM/MPH
    VA Beach
    Quote Originally Posted by IndeedSS View Post
    That is an awesome graph. Now if I put the gearing for 1st 2nd 3rd 4th in the RPM 1, 2, 3, 4 spaces, will it switch the table for me?
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  3. Which shift kit would you recommend?
    By oldsman105 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2008, 02:09 PM
  4. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
  5. warning points system
    By 3800SE in forum Forum Bugs/Suggestions
    Last Post: 01-04-2008, 07:36 AM
