Thread: WOT Shift Points...RPM/MPH
Results 1 to 15 of 15
  1. #1 Re: WOT Shift Points...RPM/MPH
    NY
    I compared my tables to the sheet for 3.29's and my 1st WOT shift rpm and mph don't match, but the 2nd shift rpm and mph do match. Is this the cause why I have a kinda strange 1-2 shift? (sorry to hijack)
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  2. #2 Re: WOT Shift Points...RPM/MPH
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    How far off are you, from the table? I'm sure that the spreadsheet is a close approximation.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: WOT Shift Points...RPM/MPH
    NY
    I've got my 1-2 shift (at WOT) 5700 rpm and 39 mph. The spread sheet says at 5700 rpm I should be at 42.75? I get a shift, then not even a half sec. later it will shift real hard...sometimes chirp. (The chirp is mainly due to my winter tires being only 15's and real narrow I'm guessing)
  4. #4 Re: WOT Shift Points...RPM/MPH
    GT Level Member japslpr's Avatar
    VA Beach
    Quote Originally Posted by monte0 View Post
    I would put the MPH closer to what the table says and then scan to get it closer.
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  5. #5 Re: WOT Shift Points...RPM/MPH
    NY
    I'll give it a try
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  3. Which shift kit would you recommend?
    By oldsman105 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2008, 02:09 PM
  4. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
  5. warning points system
    By 3800SE in forum Forum Bugs/Suggestions
    Last Post: 01-04-2008, 07:36 AM
