Thread: Overkill pcm installed. Love it but...
Results 1 to 9 of 9
  1. #1 Overkill pcm installed. Love it but...
    SE Level Member 04compggtp's Avatar
    Feb 2009
    new york
    Hey everyone, I finally completed my mods with the overkill pcm. I have driven it for the past few days because the weather has been warmer. I usually don't drive it in the winter but wanted to see how it performed. I am very pleased with the performance I now have. What a difference from when I first joined this site. I have read many of the links and have taken suggestions from many. I have learned much from you guys! The overkill pcm is great. I still need to get a scan and plan on doing that in may when the weather is better. I have one concern that maybe someone knows something about before I contact will at Overkill. Like i said, the performance aspect of the pcm is great, but now my cruise control will not work properly. It will engage, but only for a short time before it disengages.( about 45 sec.) Has anyone had or heard of this problem? Is the pcm still trying to get used to my car, or is there something within the pcm settings that might be tripping the cruise control? I just wanted to throw this out to the forum before I contact Will. Thanks ahead for your help.
    Thrasher cai, s&b 9",zzp stainless power log, zzp 3" cated dp, :180*t stat, autolite 104's, overkill pcm,: thrasher 3.4 modular pulley,F&R drilled/slotted rotors. 245/45/18 Fierce on Casino's
  2. #2 Re: Overkill pcm installed. Love it but...
    Nov 2008
    Burkburnett, Texas
    I have the same problem but I have a stock PCM still.
  3. #3 Re: Overkill pcm installed. Love it but...
    Feb 2009
    new york
    I'm going to put the stock pcm back in to check and make sure that the pcm is or isn't the problem first
  4. #4 Re: Overkill pcm installed. Love it but...
    Bastard Reptile's Avatar
    Kansas City, MO
    Also, if it does it with your stock pcm, check your brake lights to make sure they are all working. Don't ask, but they have something to do with it. LOL
  5. #5 Re: Overkill pcm installed. Love it but...
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    my cruze doesent work, it will everyonce in awhile... I figured it has something to do with my traction control not working..
  6. #6 Re: Overkill pcm installed. Love it but...
    Feb 2009
    new york
    update: I put the stock pcm back in and drove for 1 hour with cruise having no issues. This means that a setting on the overkill pcm is triggering the cruise to shut down. Has anyone had this problem with their overkill pcm? I have e-mailed will and am waiting for his reply.
  7. #7 Re: Overkill pcm installed. Love it but...
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    so did you ever get this solved? i do plan on getting an overkill pcm in the future (next week, next year, who knows) but having no cruise control would definetely change my mind on that purchase.....
  8. #8 Re: Overkill pcm installed. Love it but...
    Feb 2009
    new york
    I have sent my overkill pcm back to will and he has been great about figuring out what the problem was. He actually brought his old 04 comp g into the shop to simulate the problem I was having. Turns out it was a simple fix. Will has been great about responding to my e-mails. Although he is super busy, he has addressed the problem and offered to fix it and cover all shipping involved. I love the difference in how my car performs and wills pcm programing is the key. I am running a 3.4 pulley, and only get 3 degrees of kr running wide open just before shift change. only 1 degree constant wide open throttle. I think that's good. I definitely would order from Overkill motor sports.
  9. #9 Re: Overkill pcm installed. Love it but...
    Donating Users blowfishRus6's Avatar
    g.a.
    thats pretty good for a 3.4 with plog and downpipe.
    how much does it come out to in the end if you keep your stock pcm with shipping and all??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. i love gpf...
    By 2000GTP in forum Off Topic Discussion
    Last Post: 01-25-2009, 05:05 PM
  2. Anyone else love their job?
    By Sabrewings in forum Off Topic Discussion
    Last Post: 12-15-2008, 08:56 AM
  3. Installed Overkill PCM
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:25 PM
  4. GXP Love
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 02:49 AM
  5. 9c1 love
    By Sinister Drag Designs in forum Off Topic Discussion
    Last Post: 12-18-2007, 05:54 PM
