Thread: Will A 99 GTP DHP PCM work in a 98 GTP
Results 1 to 11 of 11
  1. #1 Will A 99 GTP DHP PCM work in a 98 GTP
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Im getting a 99GTP pcm for my 98 GTP and was wondering if it will run right, I was told that it 98-02 PCM are interchangable, Has anyone had experience with this that knows?
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    yes. they are the same. it is also better to have a 99 .bin since that is when they figured out how to make the car run well.
  3. #3 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The difference in the MAF calibration doesn't make a difference?
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    ****, that's right. 98s have that stupid retardo MAF. i never had to deal with that because i always had a 99+ MAF in my 98.
    get a new throttle body at the same time and call it good. or hog out the one you have and put in a 99+ MAF. then youll be set.
  5. #5 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    stanford Ky
    thats good to know that I dont have to change tb and maf.
    thanks
    99 gtp- sold
  6. #6 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    QCA, IA
    I think you misunderstood, yes, you DO have to change the TB and MAF.
  7. #7 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    it might run...it might run badly, im not sure because i never tried it. youre going to need a 99+ style MAF for the calibration to be right. you CAN use a 99+ style MAF in your current throttle body, but youll have to hog it out and get rid of that beam that runs down the middle of the throttle body. the bolt pattern of the MAF is the same.
  8. #8 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    QCA, IA
    hogging out the 98 TB and drilling a new hole for the 99+ MAF would still require a tune, though, since the diameter the MAF is reading is different than it would be in a stock 99+ TB.
  9. #9 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    youd still have the 99 MAF and the right calibrations for it. im not saying that he shouldnt get a tune, but the car would run alright for the time being.
  10. #10 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    QCA, IA
    No, the calibration depends on the exact cross section of the bore that the MAF is reading from. A bored out 98 is going to have a different cross section than a stock 99.
  11. #11 Re: Will A 99 GTP DHP PCM work in a 98 GTP
    you win. get a new throttle body too. im sure you can get one for pretty damn cheap.
  1. my way to work
    By mileyguard in forum Off Topic Discussion
    Last Post: 03-25-2009, 09:33 PM
  2. Will this work??????
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2008, 08:40 AM
  3. Work
    By TheOtherNick in forum The Rant Forum
    Last Post: 10-14-2008, 09:30 PM
  4. G.I. In Fab work
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 06-27-2008, 10:33 AM
  5. Will this work?
    By sra_chipmunk in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2008, 09:12 AM
