Thread: AFR Error will not work.
Results 1 to 20 of 21
  1. #1 Re: AFR Error will not work.
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    So if i set up my AFR error table like the way yours is set up i would be able to Maf tune my GP using the data acquired within that graph?
  2. #2 Re: AFR Error will not work.
    yes exactly what you want. my scanner set up for maf vs wb
    the 9.7 there would be a 10 but i had to play with it a bit to make it match the scanner vs the gauge.
    Quote Originally Posted by chrisrexmandie View Post
    those two are what i use for maf vs wb.
    dont need the wb error for maf tuning at all. just VE tuning.
  3. #3 Re: AFR Error will not work.
    Sep 2018
    NC
    Hmmmm looks like the only thing different with your WB error vs Maf chart and mine is the error math i will change mine and see. It was strange how i was getting no data at all. I was told in order to tune using the maf you needed a wideband one you get to a certain HZ because then your fuel trims no longer play a role in the fueling. Was i told wrong?
  1. Replies: 2
    Last Post: 05-15-2016, 05:42 PM
  2. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  3. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  4. Remote start - Used to work great now after some messing around it does not work.
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2012, 11:24 AM
  5. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
