Quote Originally Posted by brettstoner View Post
You would only use Tiny Tuner to edit any tables you cannot edit in DHP. Then read/write with DHP. Tiny Tuner is just used to edit tables and even then most use it to edit tables not in DHP. There was an E85 guide on the old .net and maybe it is on the .com if you search around.
The defacto guide to tuning your car for e85.
I think this is the thread you were referring to. Either way, I would use DHP not tiny tuner to make the needed changes. The only time I used Tiny Tuner was if DHP didnt contain the table I wanted to modify.
