Thread: 16.41 LTFTs on decel/sometimes idle
Results 1 to 9 of 9
  1. #1 16.41 LTFTs on decel/sometimes idle
    Jan 2017
    xx
    This started after installing the 60# injectors and moving to E85.
    Actually, I can say it started after putting the injectors in. I noticed high LTFTs on decel on the way to the gas station to get the E85. This only happens on decel and sometimes at idle (but they're still high at idle, usually 8-10). If there's a vacuum leak somewhere, I can't find it. I have gone over every vacuum line with propane, brake clean, and soapy water. I have also tried taking the EVAP vacuum line off the TB and blocking that. Took the middle vacuum line off the S/C tree and capped that. Nothing different.
    The car is tuned for the injectors and for the E85 (using frosty's method). Last night I was cruising along and I watched the wideband go nearly full rich (.70 lambda), and a few seconds later it tripped P0171.
    Now, I have read that some people suggest re-tuning the MAF after swapping injectors.. other's don't. Could that cause the LTFTs to go haywire? Any other ideas or places to look for a vacuum leak? I've spent the last hour searching through threads on here and other forums trying to find something that I haven't tried yet, but I'm coming up very short. Getting .72-.73 lambda at WOT, 3.2 pulley, the car runs like a raped ape. Just trying to track down the stupid LTFT problem..
  2. #2 Re: 16.41 LTFTs on decel/sometimes idle
    Kemmerer, Wyoming
    Don't even be a little concerned about a lean fuel condition in deceleration. Your car is programmed to do that. I wood verify your injector flow rate is correct and tat your cylinder gain is where it should be, and maybe check the actual ethanol content of your fuel and if those all check out right then do a Maf adjustment.
  3. #3 Re: 16.41 LTFTs on decel/sometimes idle
    You always have to tune the MAF curve when going to larger fuel injectors. Just scaling tables to fudge numbers is not the correct way to do things. The MAF sensor is controlling how much fuel is going into the motor based on airflow calculations.
    Decel is decel, it's not needing the fuel so it takes it away and very oftens enters DFCO to shut off the injectors completely.
  4. #4 Re: 16.41 LTFTs on decel/sometimes idle
    Jan 2017
    xx
    Thanks, guys. This is the one time I wish I had HPT vs. DHP/TT because MAF tuning with DHP blows.
  5. #5 Re: 16.41 LTFTs on decel/sometimes idle
    Jan 2017
    xx
    Did 1 MAF tune with the Table Modifier last night and it's already getting better.
    My question is this.. doesn't Eddie's table modifier only look at the MAF when you're not under boost/PE? How would it smooth out and fix the rest of the table? Maybe I just have a fundamental misunderstanding of what it does.
  6. #6 Re: 16.41 LTFTs on decel/sometimes idle
    the idea is to run through the rpm's and cover each kpa cell slowly without much boost. if you hit boost the rpms will go faster to the end of the maf cells.
  7. #7 Re: 16.41 LTFTs on decel/sometimes idle
    Jan 2017
    xx
    Yeah I've been rolling into the throttle slowly when I scan it. So does that mean the higher frequencies of the MAF table never gets adjusted?
  8. #8 Re: 16.41 LTFTs on decel/sometimes idle
    you want to cover as many cells as possible, if you floor it it skips all the mid and low cells.
  9. #9 Re: 16.41 LTFTs on decel/sometimes idle
    They can still be adjusted, it's just a matter of if you need to remove or add fuel to match your commanded AFR under WOT.
    If you commanded 11.5 but saw 11.8 on the wideband you'd add like 2% worth of fuel to the MAF curve to richen it up and see how close you get to your target.
  1. -20% LTFTs What else?
    By Booba5185 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2014, 08:23 PM
  2. Replies: 7
    Last Post: 02-06-2014, 04:47 PM
  3. trans. whines on decel any ideas
    By LEE04 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2012, 05:28 PM
  4. LTFTs at -22.06
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 12:22 PM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
