This started after installing the 60# injectors and moving to E85.
Actually, I can say it started after putting the injectors in. I noticed high LTFTs on decel on the way to the gas station to get the E85. This only happens on decel and sometimes at idle (but they're still high at idle, usually 8-10). If there's a vacuum leak somewhere, I can't find it. I have gone over every vacuum line with propane, brake clean, and soapy water. I have also tried taking the EVAP vacuum line off the TB and blocking that. Took the middle vacuum line off the S/C tree and capped that. Nothing different.
The car is tuned for the injectors and for the E85 (using frosty's method). Last night I was cruising along and I watched the wideband go nearly full rich (.70 lambda), and a few seconds later it tripped P0171.
Now, I have read that some people suggest re-tuning the MAF after swapping injectors.. other's don't. Could that cause the LTFTs to go haywire? Any other ideas or places to look for a vacuum leak? I've spent the last hour searching through threads on here and other forums trying to find something that I haven't tried yet, but I'm coming up very short. Getting .72-.73 lambda at WOT, 3.2 pulley, the car runs like a raped ape. Just trying to track down the stupid LTFT problem..
