Thread: UVScan install issues
Results 1 to 7 of 7
BoostedPontiac UVScan install issues 04-01-2017, 03:07 PM
SaukRapids Re: UVScan install issues 04-01-2017, 04:42 PM
Scottydoggs Re: UVScan install issues 04-01-2017, 10:41 PM
digitaloutsider Re: UVScan install issues 04-01-2017, 10:49 PM
lance4682 Re: UVScan install issues 04-02-2017, 05:43 PM
Scottydoggs Re: UVScan install issues 04-02-2017, 06:14 PM
BoostedPontiac Re: UVScan install issues 05-10-2017, 10:41 AM
  1. #1 UVScan install issues
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    ok, im running windows 7 starter on a mini hp laptop. im having issues installing the uv scan software. ive tried all of the different uv scan variants in the dropbox account and it still gives me the same "exception EOleSysError in module uvscan.exe at 00087B71. Class not registered." any ideas on how to get it to work.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: UVScan install issues
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    That looks like a compatibility issue with Win7. There's ways to try and force the driver. I don't remember alotta this, so I had to look it up.
    Maybe this will help, scroll down and there's some instructions - https://forums.techguy.org/threads/e...gistry.916096/
  3. #3 Re: UVScan install issues
    works fine on my win 7 laptop. you need to set up the comm port and speed just like dhp registration. might have to run as admin.
  4. #4 Re: UVScan install issues
    Jan 2017
    xx
    UVScan was really buggy for me, but yes it must be run as admin. I couldn't even get it to connect without doing that.
  5. #5 Re: UVScan install issues
    Nov 2012
    pistolvania
    let me know if you figure this out having the same issue on win 10 tablet ...i finally got one of the uvscans to work but it would pull bad scans that would not read on eddies table modifier
  6. #6 Re: UVScan install issues
    all of these reasons are why i hardly used uv scan. buggy f er for sure. i just stick with the dhp scanner. it works just fine for me.
  7. #7 Re: UVScan install issues
    Apr 2014
    South Haven, MI
    I figured out the pt scanner and wideband formula. Turns out laptop needed to update a few times.
  1. Uvscan 3
    By gambler87 in forum PCM Tuning
    Last Post: 04-12-2014, 06:03 PM
  2. Wide Band Logging thru EGR using UVScan.
    By Z34Phoenix in forum PCM Tuning
    Last Post: 01-07-2014, 09:55 AM
  3. I got some serious issues following zzp 350 pump install
    By shawnschuldt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2012, 01:54 PM
  4. header install issues
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2012, 10:33 AM
  5. UVScan
    By Lawngoose in forum PCM Tuning
    Last Post: 10-09-2011, 08:30 PM
