Thread: Turbo Gtp stuck in open loop in WOT
Results 1 to 13 of 13
  1. #1 Turbo Gtp stuck in open loop in WOT
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    So I recently bought a turbo gtp has the cartuning kit with a 65mm precision turbo. it absolutely did not want to idle when I bought it. Finally got it to idle started doing some wot scans it will not stay in closed loop during my normal time PE should kick on. Hpt says "OL - not ready" under fuel status when everything meets requirements for pe. Any ideas? I'm out
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Turbo Gtp stuck in open loop in WOT
    PE is always open loop.
    Anything outside of WOT can use closed loop.
  3. #3 Re: Turbo Gtp stuck in open loop in WOT
    GT Level Member mguzzo's Avatar
    Buffalo NY
    ^^ PE is open loop, locks in the last LTFT
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: Turbo Gtp stuck in open loop in WOT
    Nebraska
    Ok so I guess my next question is why on my other gtp my fuel status says PE Under fuel status and this one says open loop not ready? My afr at wot is way to lean around 14 to 15. It's set to be 10afr. I may just have to play with my maf that much I guess? It seems like it's not using the maf for fueling at all.
  5. #5 Re: Turbo Gtp stuck in open loop in WOT
    Quote Originally Posted by 94GrandPrixSE View Post
    My afr at wot is way to lean around 14 to 15. It's set to be 10 and that's what I'm getting.
    this line makes no sense to me. is the AFR at WOT 14-15 or 10?
  6. #6 Re: Turbo Gtp stuck in open loop in WOT
    Nebraska
    Quote Originally Posted by fst View Post
    Fixed, not sure what I was trying to say lol. It's set to 10 in my pe table and I'm no where near that.
  7. #7 Re: Turbo Gtp stuck in open loop in WOT
    ok. im use to running in OLMAF so I wouldn't have to worry about closed loop or open loop and playing around with the narrowband since I use a wideband in its place. are you getting any DTC codes related to the "OL not ready" like bad o2 sensor?
  8. #8 Re: Turbo Gtp stuck in open loop in WOT
    Nebraska
    No and it seems to be switching normally
  9. #9 Re: Turbo Gtp stuck in open loop in WOT
    so when you enter PE does the log/scan say PE? Powrtuner scan/log in the parameter would have a field that says closed loop and open loop when entering PE based on throttle percentage.
    edit-also are you using a wideband to verify the afr?
  10. #10 Re: Turbo Gtp stuck in open loop in WOT
    Nebraska
    No it's says OL - not ready. Yes I'm using a wideband and scanning it right on hpt
  11. #11 Re: Turbo Gtp stuck in open loop in WOT
    is the 14-15:1 on the wb at 100% throttle? if so, im surprised the motor's in one piece lol.
  12. #12 Re: Turbo Gtp stuck in open loop in WOT
    Nebraska
    Somehow yeah barely any knock too unless something is reading wrong
  13. #13 Re: Turbo Gtp stuck in open loop in WOT
    Motors lucky so far lol. I easily chipped #5 going partially lean at part throttle around 14:1
  1. Clunking when put into gear in open loop
    By RedneckGTP in forum General Grand Prix Discussion
    Last Post: 10-24-2013, 09:14 PM
  2. Open Loop - does PCM scan KR?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2013, 09:12 AM
  3. P0171 open loop
    By gtpsleeper in forum PCM Tuning
    Last Post: 10-19-2011, 04:05 PM
  4. Open/Closed Loop Operation
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2009, 08:52 PM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
