Thread: Eliminating KR - I think I see the problem?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Eliminating KR - I think I see the problem?
    Jan 2017
    xx
    Is it kosher to put a wideband after the cat in the rear O2 bung? I see a lot of mixed opinions.
  2. #22 Re: Eliminating KR - I think I see the problem?
    i find it ok to install it there, where mine is.
    i just went over his tune, he was missing a tune pretty much. sent a new tune, pretty sure i might be his new hero lol
  3. #23 Re: Eliminating KR - I think I see the problem?
    The location after the cat is okay, just not putting it after the cat itself isn't.
    The cat converter at part throttle can skew wideband readings and make it slower to respond than if it was infront of the cat. At WOT after a second or so of delay "should" still show very close AFR readings to a wideband in front of the cat because the cat converter isn't doing **** to the gases when there is so much flowing through it at once. They are not designed to work good at full throttle, that's why they need to flow lots of air and not be a restriction. Idle and part throttle is where the cat is doing all it's work.
    That is why when tuning with a wideband it should be infront of the cat to prevent skewing/problems.
  4. #24 Re: Eliminating KR - I think I see the problem?
    Jan 2017
    xx
    Yeah, pretty much. You saved me a lot of pulling my hair out.
    As for the wideband, I'll get one and I look forward to tweaking it more!
  1. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. Ac problem
    By mharris in forum General Grand Prix Discussion
    Last Post: 07-01-2012, 01:06 PM
  5. BCM problem
    By Paulio0907 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2009, 04:41 PM
