Thread: What rpm should I shift at?
Results 1 to 9 of 9
  1. #1 What rpm should I shift at?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys I'm just curious what I should set my shift rpm at. Currently it's at 5700 which means it actually shift more around 5900 at wot. I have a stock cam but have l76 springs and yella terra 1.9 rr. I'm assuming it's bad for the trans to shift at higher rpm to right? Thanks!
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: What rpm should I shift at?
    May 2008
    Schuyler, NE
    Higher rpm doesn't hurt the trans, as long as it's not pumping the pan dry.
    Shifting at 5900 on rockers and l76 springs, sounds about right. If you are getting valve float, you can decrease it some. But other wise, I would leave it.
  3. #3 Re: What rpm should I shift at?
    Agreed, just leave it be.
    No real need to go higher or lower at this time.
  4. #4 Re: What rpm should I shift at?
    Oct 2015
    Ok, i wasn't sure if the rockers made good power at a little higher rpm, but thank you I will just leave it be ☺
  5. #5 Re: What rpm should I shift at?
    You are limited by your camshaft, not the rockers for power.
    The stock cam is already out of power at 5,600-5,700.
  6. #6 Re: What rpm should I shift at?
    Oct 2015
    I just thought rockers made good power at the higher rpms but I don't really know to much that's just what I was told.
  7. #7 Re: What rpm should I shift at?
    while you can turn the shift point up, ive done it, and turned em back down to 5700 i think, cause its dead rpms no power is being made past that.
    at the track i shifted into 3 rd at the finish line @ 97 mph. if it had shifted sooner, i think i would have done better then a crappy 14.3.
  8. #8 Re: What rpm should I shift at?
  9. #9 Re: What rpm should I shift at?
    May 2008
    Schuyler, NE
    Rockers do give you a little more rpm up top, hence why I recommend to shift it at 5900.
  1. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  2. zzp shift kit or intense shift kit
    By ScammingL67beast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2013, 10:50 PM
  3. Shift kit
    By rperry435 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-08-2013, 09:28 AM
  4. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  5. shift
    By mik01gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2011, 06:18 AM
