Thread: Learning to tune
Page 4 of 4 FirstFirst ... 234
Results 61 to 71 of 71
  1. #1 Re: Learning to tune
    Kemmerer, Wyoming
    I have my PE enable set to 30% tps across the board. your transmission settings should be changed so your torque converter can't lock unless you are in 3rd or 4th gear, some people just let it lock in 4th gear only. I used UV scan when I had my dhp, it is much better than the dhp scanning software.
    968 sounds like an O2 sensor reading, and if that is what you are referring to, it doesn't really have anything to do with mg/cylinder as that is in relation to air flow.
  2. #2 Re: Learning to tune
    Aug 2016
    MN
    I was in 3rd gear when this was showing up. My O2 levels haven't gotten quite that high as I'm avoiding WOT until I can get these KR issues worked out. On UVscan it's listed under Fake PIDS (which is why I wondered if their results were reliable) as airflow mg/cylinder and I have values ranging from 69 to 968 varying with throttle.
  3. #3 Re: Learning to tune
    everything varys with the throttle.
  4. #4 Re: Learning to tune
    Donating Users
    Jul 2016
    Youngstown Ohio
    Just drove to Norwalk Drag today from Youngstown 3.35 pulley DIC showed 29.5 mph that's driving at 78mph. Tune makes a difference.
  5. #5 Re: Learning to tune
    Buffalo
    No. A few locals here with n/a Regals had kr like crazy
  6. #6 Re: Learning to tune
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I had ~5° kr at 48% throttle with my stock tune... Lol
    BTW thanks again, Scotty.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  7. #7 Re: Learning to tune
    Quincy, Mass
    My wife's ok gets about 7 and its all stock. Overkill Pcm gave it 14*.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Learning to tune
    Kemmerer, Wyoming
    Quote Originally Posted by Swiggles View Post
    any idea what was in the tune that caused the kr?
  9. #9 Re: Learning to tune
    Aug 2016
    MN
    Logged today, results are better, still seeing some KR. LTFTs are closer, max of -10 now. Going to tune the maf some as well as pull some timing where my KR is showing and see where that brings me.
  10. #10 Re: Learning to tune
    Aug 2016
    MN
    Well, after some more adjustments including a decent increase in cruise timing, my mileage increased from roughly 28 mpg to 32 mpg highway, confirmed by both DIC and topping off the tank before and after my trip to the cities. Only occasional blips of KR showing up during normal driving, which I'll adjust to get rid of. So you guys were right, I could learn to tune.
  11. #11 Re: Learning to tune
    Quincy, Mass
    I think it was more tune up stuff and a clogged coolant system that was doing. It was the base shelf tune as far as I know. I have since sold that pcm but have another one that's an 06 pcm that I haven't tried yet.
  1. New and learning
    By Misty in forum Introductions/Noob Questions
    Last Post: 01-07-2012, 01:07 PM
  2. New here, learning a lot. but I got GXP questions!
    By suctoes in forum General Tech Discussion
    Last Post: 03-30-2011, 11:29 PM
  3. EGR learning
    By GreyGhost in forum General Tech Discussion
    Last Post: 03-01-2011, 08:26 AM
  4. Learning the Ropes
    By dbwilli in forum Introductions/Noob Questions
    Last Post: 08-08-2009, 08:59 PM
  5. new guy learning
    By 98gtp1000 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:49 AM
