Thread: p0300 code w/ N* tb lq4 and tre 80lb injectors
Results 1 to 20 of 21
  1. #1 p0300 code w/ N* tb lq4 and tre 80lb injectors
    SE Level Member 40thAnnGTP2002's Avatar
    May 2015
    high point nc
    hello all fellow w-body people I am trying to fig out a p0300 random misfire code I have. First off, it is ONLY at idle and no other time. 2nd)I have the following mods; Gen v w/ a 2.8 and KYGTP Beltwrap(THANKS AGAIN STEVE!) and Northstar Throttle Body w/ LQ4 MAF on 16* timing with yella terra 1.95 roller rockers and crow 105# springs w/ zzp modded retainers and comp valve locks, also have Tre 80lb injectors and a Tre 255 fuel pump with a caspers hotwire kit. I am on E85 and also a milzy fsic fb 101 fmhe flowjet ic pump. I have factory Acdelco wires and AL 103 plugs gapped at .045. I don't have an EGR Valve bc I deleted it and I also deleted Evap solenoid. Car runs great other than the random misfire, I can feel it but have no clue whats causing it bc as soon as I give it gas-it goes away. 3rd) I have tried the following; diff plugs and wires, maf, map, idle air control valve, sprayed brake cleaner around intake and sc for leaks and I have 0. also tried all diff coilpacks, icm, and even reverted back to l67 throttle body. I have used tiny tuner and played w/ inj offset vs battery voltage and low pulse width inj offset vs pulse width vs map. ANY AND ALL HELP WOULD BE GREATLY APPRECIATED!!!
    The joy of getting pulled on an interstate...
    Cop: "License & Registration, Do you know how fast you were going?" Me:"I was just trying to keep up with the traffic." Cop Looks Around:"There is no traffic." Me: "I know, that's how far behind I am!!!"
  2. #2 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Raise the idle rpm or delete the code is what I would do.
  3. #3 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Kemmerer, Wyoming
    with most aftermarket cams, the vendors recommend disabling the P0300 code because of the random misfire. I would suspect your combination is setting it as well.
  4. #4 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I didn't see he has a cam, only high lift rockers. I agree there's something about the combo. maybe just enough lift on the stock duration that allows enough fresh air past to trick the PCM into thinking there's a misfire
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    May 2015
    high point nc
    I can feel the misfire tho
  6. #6 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    May 2015
    high point nc
    Its driving crazy thats its only at idle and no other time
  7. #7 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Quincy, Mass
    The 103s might be too cold for that set up unless they are needed for the e85.
    No more GP 04 Impala SS Indy:
  8. #8 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    May 2015
    high point nc
    I tried 104s and also stock iridium w no change. Had 103s in before e85 and fsic and n* setup w no issue
  9. #9 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Kemmerer, Wyoming
    I thought 103's would be ok because he is making like 15 lbs of boost
  10. #10 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Raise the idle.
  11. #11 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Quincy, Mass
    Iridiums are no good with boost, copper works better for us. It's been awhile for me but I only remember using 103 once I had ported heads and is3 can and when I was turbo, but like I said it's been awhile.
    I agree try raising the idle 100 rpms
  12. #12 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    May 2015
    high point nc
    Idle has been raised already. I did that last night
  13. #13 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    Kemmerer, Wyoming
    Quote Originally Posted by 40thAnnGTP2002 View Post
    Do it again, 1200 rpms
  14. #14 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    1200 is pretty high, I woulda said 900rpm over the factory 650ish.
  15. #15 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    hangover park IL
    It's more likely that it would be a clogged or streaming fuel injector.
    What is the history on your injectors? You may want to remove the coil packs from the ICM and flip your rails upside down and crank it over to see if one of them is bad
    ~James~ Psychotic Gearhead
  16. #16 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    May 2015
    high point nc
    Switched coils and icm and brand new injectors.
  17. #17 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    GXP Level Member
    Mar 2015
    Tomball
    Didn't a guy just go through all of the usual suspects the other day and had a loose reluctor on the balancer, re-tightened it and put some locktite and all was good with the world again?
    Jeff
  18. #18 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    there was a guy,,, but hes failed to update the thread.
    he got it figured out, something with the injectors in TT needed to be changed cause they are so damn big.
  19. #19 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    GXP Level Member
    Mar 2015
    Tomball
    Actually he did here is the thread.
    http://www.grandprixforums.net/threa...re-figured-out
  20. #20 Re: p0300 code w/ N* tb lq4 and tre 80lb injectors
    i know about that thread, i meant 40thanngtp2002 failed to update.
  1. Relentless P0300 code
    By gofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2016, 08:50 AM
  2. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  3. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  4. most common p0300 code fix
    By Wingsfreak9 in forum General Tech Discussion
    Last Post: 09-21-2011, 01:12 PM
  5. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
