Thread: Learning to tune
Results 21 to 40 of 71
  1. #1 Re: Learning to tune
    Buffalo
    Anyone wanna prove me wrong? Come see me
    i have beers good food and free time
  2. #2 Re: Learning to tune
    GXP Level Member
    Mar 2015
    Tomball
    I never did better than 26mpg on a 4 hour drive. My timing was stock and I cruise in the high 30's to 46*. I wouldn't add timing since I already have 05' tables. I just don't get it.
    Jeff
  3. #3 Re: Learning to tune
    Buffalo
    No one wants to have some beers , steaks and whisky? Bone apple tea
  4. #4 Re: Learning to tune
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Quote Originally Posted by CrazyGuy03 View Post
    It's a bit of a drive, to be quite honest... At least for me. Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #5 Re: Learning to tune
    Quincy, Mass
    sorry mitch i forgot about sending you the turbo tunes, theres some others ill send you too that might help you get started with this one too.
    try a 3.6 pulley to start, shouldnt need to go back to stock size and do the maf tune. Might want to consider a N* throttle body for it too with those other mods.
    the maf tune alone will get rid of some knock.
    No more GP 04 Impala SS Indy:
  6. #6 Re: Learning to tune
    Aug 2016
    MN
    Quote Originally Posted by Swiggles View Post
    I'm hoping so, it's relearning the ltfts now. I've been kicking around the idea of doing a N* TB, but I haven't made a decision yet. Don't really want to put more money into the GTP though. And I'm looking forward to seeing the bins you send, I always like to see what others have done as a general guide.
  7. #7 Re: Learning to tune
    Quincy, Mass
    Can take 200 miles, or 10 drive cycles for them to fully settle.
    I've always wondered do we have to wait that long or can we just drive around for 20 mins while they settle?
  8. #8 Re: Learning to tune
    If you had HP Tuners you could wait maybe 10 miles and everything is back to normal but DHP takes forever.
  9. #9 Re: Learning to tune
    Aug 2016
    MN
    Why is that? lol! I obviously am new at this, but isn't a fuel trim reset the same regardless of whether dhp, hpt, a dealer, or a battery disconnect causes it?
  10. #10 Re: Learning to tune
    GXP Level Member
    Mar 2015
    Tomball
    This is what I don't understand. What difference does it make which program is used, if the fuel trims are wiped out when using either program the PCM is doing the relearning not the program, at that point it's not attached. Can someone explain the logic behind tuning with HPT allowing the the trims learn faster? When you disconnect the battery for an extended period of time it is going to have to learn the trims as well what makes any of these things any different?
    Jeff
  11. #11 Re: Learning to tune
    hp has a auto fuel trim learn feature. dhp does not.
  12. #12 Re: Learning to tune
    Aug 2016
    MN
    Really? I wonder how that works? So do they leave the programmer connected after the reset the trims then?
  13. #13 Re: Learning to tune
    Kemmerer, Wyoming
    it just does it like magic. I'm not sure how, I just know it works.
  14. #14 Re: Learning to tune
    Oct 2014
    Frederick, MD
    While DHP does take an annoyingly long time, you can use it on just about any w body or similar gm car...pretty sure there's some GA bins in the drop box. Lol
  15. #15 Re: Learning to tune
    Aug 2016
    MN
    Ok, so quick question, when you are trying to dial in the ltfts, does that include when the car is in Deceleration, or is that allowed to go negative?
    Also, if I want to use to use the A/C RPM/TPS disable available in tiny tuner, is there anything in particular I need to do or is it as simple as loading my bin, making the changes, and then flashing it with DHP?
    I'm getting ready to do my first log for a MAF table adjustment.
  16. #16 Re: Learning to tune
    you dont want pos long term trims, you want them on the neg side.
    as ass backwards as it is, pos is lean, neg is rich.
    id never touch those settings...whats the point? and yes, you make changes then flash it, tt saves it as a bin file. rename it and use that file a your new one.
  17. #17 Re: Learning to tune
    Aug 2016
    MN
    Ok, I'm confused. Just took my real first scan, and I have KR showing up at 80 kpa?! That's not even into boost. I think my prior scan was in open loop. My O2 readings are also all over the place. I have from 30 all the way to 907, in some cases making 700 point swings between frames! I'm thinking that shouldn't be normal... Would this be a bad O2 or an exhaust leak somewhere? LTFTs still solidly negative -20 to -10 mostly.
  18. #18 Re: Learning to tune
    o2 sensor are suppose to swing over and under 450mv. That is how they work, they swing lean or rich of stoich making corrections quickly.
    Under heavy throttle the bank 1 o2 sensor should jump up to around 900mv as you are pushing alot more air and fuel into the cylinders, thus becoming much richer than 14.7:1 afr.
  19. #19 Re: Learning to tune
    Aug 2016
    MN
    Well, that makes me feel better, but what would cause KR @ 80 kpa? Is my timing that far off? or would something else cause that?
  20. #20 Re: Learning to tune
    your reading things wrong, the kpa has nothing to do with the kr. check your timing and ltft. if the fuel trim is a large pos # your lean.
    as far as timing, you look at the rpm its starting at, and lower it accordingly, say you had 4º kr starting at 3200 rpm and it dont go away while wot. id pull 3º timing out of wot timing from 3200 to 6400.
  1. New and learning
    By Misty in forum Introductions/Noob Questions
    Last Post: 01-07-2012, 01:07 PM
  2. New here, learning a lot. but I got GXP questions!
    By suctoes in forum General Tech Discussion
    Last Post: 03-30-2011, 11:29 PM
  3. EGR learning
    By GreyGhost in forum General Tech Discussion
    Last Post: 03-01-2011, 08:26 AM
  4. Learning the Ropes
    By dbwilli in forum Introductions/Noob Questions
    Last Post: 08-08-2009, 08:59 PM
  5. new guy learning
    By 98gtp1000 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:49 AM
