Thread: 97 l67 IFR values same?
Results 1 to 11 of 11
  1. #1 97 l67 IFR values same?
    Donating Users timboku's Avatar
    Montgomery, IL
    Anyone know why 97gtp pcm has a flat IFR value across the board like an NA? Only year it's like that. 98 up l67s have a slopped IFR. Would it be benifical in putting slopped IFR values in a 97 that is being tuned for a turbo?
    Sent from my SM-N910V using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: 97 l67 IFR values same?
    hangover park IL
    its the evolution of the hardware/OS as GM went through obd1/1.5/2
    the v6 vehicles didn't need as much work to get to pass emissions and didn't get the R&D time that the v8 cars did for mpg/emissions.
    the slight change in njector flow rate due to its "perceived" pressure differential (fuel press vs manifold) wasn't as important as them sorting out the 4t65e's drivability
    I can only imagine what their breadboards looked like as they went through the major pcm hardware upgrades in just 4 years
    ~James~ Psychotic Gearhead
  3. #3 Re: 97 l67 IFR values same?
    Montgomery, IL
    Would it hurt/help to put the slopped IFR of later models in a 97 for a turbo build? Or stick with flat value even for 80lbs injectors?
  4. #4 Re: 97 l67 IFR values same?
    hangover park IL
    I would say to experiment, and see if things change, it may not on a stock car, on a moded it may. though im partial to the 98/99 as being the best pcm/system before the damned Enhanced EOBD2 of the 00+
    the 96/97 "obd2" sure seems like and OBD1.5 with refinements and without all the damn Com issues now that the knock system was integral in a "zit"
  5. #5 Re: 97 l67 IFR values same?
    Montgomery, IL
    Hahah agreed...use the 98 all the time...first time working with a 97....you can take a 98 pcm and out it in a 97 can you..lol?
  6. #6 Re: 97 l67 IFR values same?
    hangover park IL
    you have to repin the coonectors but that's just playing around for a little while
    "Delphi Chinese-checkers"
    fun game
  7. #7 Re: 97 l67 IFR values same?
    iirc ive read you need to swap a few pins around in the pcm plugs to use a 98 pcm.
  8. #8 Re: 97 l67 IFR values same?
    hangover park IL
    ^ late for bingo
  9. #9 Re: 97 l67 IFR values same?
    Montgomery, IL
    Might be worth it to get rid of this mega pcm..lol
  10. #10 Re: 97 l67 IFR values same?
    Quote Originally Posted by Turbocharged400sbc View Post
    ^ late for bingo
    theres a ninja round these parts ya know lol
  11. #11 Re: 97 l67 IFR values same?
    hangover park IL
    don't get me wrong, the 97 has its place. its one of the best upgrades for the older OBD1.5 stuff
  1. P0455 code with values
    By 08 gp lvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2016, 08:47 PM
  2. MAF values for NA folks
    By GeeXPee in forum PCM Tuning
    Last Post: 06-20-2011, 10:02 PM
  3. Ideal values readout
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-07-2010, 01:19 PM
  4. Can't get timing to match table values!??!
    By DanGTP in forum PCM Tuning
    Last Post: 10-25-2008, 11:45 PM
  5. Should altitude effect MAP values?
    By ghart999 in forum PCM Tuning
    Last Post: 01-11-2008, 07:23 AM
