Thread: P0455 code with values
Results 1 to 6 of 6
  1. #1 P0455 code with values
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I have a code on my car that's been on there for quite awhile. I changed the gas cap and it went out for 2 days and came back. I cleaned the plastic thing beside the filler neck lol and checked for cracks in the rubber line, all that looked good. Not sure if putting on dual magnaflow mufflers had anything to do w it. I show two codes for the same reason one says freeze frame. I have a lot of values along with this code but no clue what it means.
    Ect F. 203
    STFT B1 %. -3.1
    LTFT B1%. 7.8
    MAP inHg. 9.2
    Spark adv. -10
    IAT. F 77
    MAF. LB/MIN. 0.6
    TPS %. 3.1
    COMMAND EVAP %. 18.8
    FUEL LEVEL %. 62.7
    WARM UP DTC CLR. 14
    EVAP VP InH20. -0.169
    BARO InHg. 29.2
    CAT TE II F. 1107.5
    ECV VOLTS. 0.472
    EQ RATIO. 1.004
    Ambient. F. 59
    Tps B %. 3.1
    Command tac %. 0.4
    F= ferhrenheit
    This is Chinese to me but hopefully to one of you. It may. Thanks again gang
  2. #2 Re: P0455 code with values
    thats a large leak. under your car where the gas filler neck is, get under the car look up, you'll see the fat gas filler tube and another smaller line with it, the small one likes to rust out. its the tank vent tube. see if its wet with gas after a fill up too.
    i had the same code forever, i got a tuner and deleted it, so i never gave a crap no more. till i smelt gas after a fill up and found this tube rusted in two and hanging under the car. i rigged it back together with rubber hose, but im sure it was the cause of my evap code.
  3. #3 Re: P0455 code with values
    Nov 2011
    north bay, ontario
    Thanks scottydogs. U a mechanic?? Cuz u sure do know a **** ton. I'm gonna look right now. So it's connected to the tank and the top of filler neck.
  4. #4 Re: P0455 code with values
    not a real mechanic per say lol but a lot has blown up on my car. lol
  5. #5 Re: P0455 code with values
    Nov 2011
    north bay, ontario
    Do those numbers make sense to you, are they within range??
  6. #6 Re: P0455 code with values
    nope. im going off your code only. codes says large evap leak. its a busted line somewhere.
  1. OEM #- P0455 help !! 05 GXP
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 01-02-2016, 12:14 PM
  2. I got codes P0455 and P0449
    By DreamerGT in forum General Tech Discussion
    Last Post: 07-21-2015, 05:58 AM
  3. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  4. Check Engine code P0499 and P0455 P0455p
    By itzharrison in forum General Grand Prix Discussion
    Last Post: 09-08-2014, 10:49 AM
  5. Updated: P0455 - EGR Self-Delete?
    By SlowNA06 in forum General Tech Discussion
    Last Post: 12-14-2010, 12:49 PM
