Thread: .HPT to BIN
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
  1. #1 .HPT to BIN
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Trying to find a way to disable my CAT testing on my 02 (in sig). I cant find anyway to open up the .hpt with tinytuner nor have i seen anyone successfully do it without DHP. Has anyone found a way yet? Otherwise if someone with DHP could convert to bin for me or just delete the testing.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: .HPT to BIN
    ive done this for the guy who wrote the how to change the vin how too in this link. http://www.grandprixforums.net/threa...-hp-depository
    you can go into the db link, find a vin with your osid# then change its vin with the how to, then your hp will read and write the bin. with the older hpt vs, not the new one.
  3. #3 Re: .HPT to BIN
    Nebraska
    What version of HPT? Im using the most current.
  4. #4 Re: .HPT to BIN
    not that one lol the older vs maybe in the drop box, not 100% sure.
  5. #5 Re: .HPT to BIN
    just looked its in there. look for the last one i suppose. the newest one wont be there.
  6. #6 Re: .HPT to BIN
    if you like, send me your email, and osid#, its shown in your bin or pcm info. and i can kill the cat test in TT for ya, then email it to you, then you can change the vin#, that ive not done, the other guy figured it out.
    once the dhp bin has the right vin # it will write with htp to your pcm.
  7. #7 Re: .HPT to BIN
    Nebraska
    I found it also, so rewrite my current OSID's vin with the one on the DB? then tiny tuner will open it and i can write it with HPT? or am i missing somthing?
  8. #8 Re: .HPT to BIN
    your on target down load and set up old hpt, then the tiny tuner step for the cat test delete, and then change the vin in the bin. open and flash .
    then read it back, copy your tune to the new bin. then flash your new file back to up grade the pcm with the tune.
  9. #9 Re: .HPT to BIN
    Nebraska
    Wrote new vin to the new bin from the DB, I opened it in TT to change the diagnostics and the cat testing isnt showing up.
  10. #10 Re: .HPT to BIN
    some versions of TT dont show it, im using vs 1.9. iirc.
    you click the diagnostic folder and its in the top 8 to 10 rows of items.
  11. #11 Re: .HPT to BIN
    Nebraska
  12. #12 Re: .HPT to BIN
    Nebraska
    Also i tried V3 from the DB same thing.
  13. #13 Re: .HPT to BIN
    i hate being this guy lol but here it is, this is a 02 gtp bin.
    like i said, ill kill the cat test and email it back to ya.
  14. #14 Re: .HPT to BIN
    Nebraska
    That would be awesome scotty! thanks! see if you can send your DB for tiny tuner I think im just lacking the right date base. That way if I ever need to use TT again.
  15. #15 Re: .HPT to BIN
    i got the database here at the bottom of the page. http://theblattners.com/Projects/TinyTuner/default.html
  16. #16 Re: .HPT to BIN
    Kemmerer, Wyoming
    not sure if this has been mentioned yet, but the new version of HP Tuners will not open a bin. the previous version, 2.24 will open bins, but not the new one.
  17. #17 Re: .HPT to BIN
    Nebraska
    That's what it was, the DB on your downloads didn't have it. How do I write this on my current tune without replacing my tunes?
  18. #18 Re: .HPT to BIN
    Quote Originally Posted by SgtMarshal View Post
    post # 2 lol
  19. #19 Re: .HPT to BIN
    Quote Originally Posted by 94GrandPrixSE View Post
    once you open it im sure you can compair and copy your tune to the new bin and flash it.
    or write it as is, then read it so its in hp format already. seems safer to me, but i dont know hpt at all. i just know it can open, edit, and flash a dhp bin.
  20. #20 Re: .HPT to BIN
    Nebraska
    Its telling me I have to purchase a license even tho Vin and Serial are right, any ideas?
