Thread: .HPT to BIN
Results 21 to 40 of 71
  1. #21 Re: .HPT to BIN
    Kemmerer, Wyoming
    I ran into the same problem last year, and couldn't find a work around. are the osid's the same on both files?
  2. #22 Re: .HPT to BIN
    thats odd, it should not know the difference. if theres another bin with the same osid try that one.
    whats your osid? i might have one set up already. then you can just change the vin and try that one. i know the one i got worked for the guy.
  3. #23 Re: .HPT to BIN
    the other thing is to make sure the vin # has matching cap letters too. if you put in lower case it may not like it.
  4. #24 Re: .HPT to BIN
    i have osid # 12585094 and 12218863 on hand
  5. #25 Re: .HPT to BIN
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Thanks for the help guys, serial number was off by 1 number. Finally got the no cat testing bin turned into a .hpt and about to open it with the updated HPT. Its a real PITA when you cant have two versions of HPT installed at once. Just need to figure out how to combine the tunes now. Can I rewrite the vin and serial on any GP to avoid licensing? Out of curiosity
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  6. #26 Re: .HPT to BIN
    yup, its one way around hpt licensing. why its nice to have a dhp too, it can change a vin number for most pcm's.
    ive not used hp, but i hear about the compare two bins option, do that and i guess you can copy over your tune that way .
  7. #27 Re: .HPT to BIN
    Nebraska
    Right when I think its going to finally work.. "Validate checksum failed. You will be unable to flash or save this file".
  8. #28 Re: .HPT to BIN
    Kemmerer, Wyoming
    HP Tuners will open the bin that you used TT to modify, and as long as everything jives, the bin will load. it seems that HP Tuners will no longer be supporting the .bin file format, so be sure to save the 2.24 format someplace for future use, "just in case." I have 2 machines that I use for tuning, my laptop, and a cheap windows 10 tablet. I bought the tablet for 100 dollars, and use it most of the time, but it's nice to have a spare. I'm thinking about downloading the new HP Tuners 3.2 software onto my laptop and trying it out again. I wanted to use the serial input feature that the 3.2 offers, but I couldn't ever get it to work, and it might be an issue with my tablet, I think that now because the innovate mtx-l gauge setup software wouldn't hookup to the gauge, and as soon as I brought out the laptop it worked without an issue.
  9. #29 Re: .HPT to BIN
    Kemmerer, Wyoming
    Quote Originally Posted by 94GrandPrixSE View Post
    is that with the HP Tuner software?
  10. #30 Re: .HPT to BIN
    Nebraska
    Yes trying to open my .hpt file, says i own the license on it tho.
  11. #31 Re: .HPT to BIN
    theres a ignore flash checksum in TT, not sure how to use it, the bin i opened has 255 as its value and no other info for it.
  12. #32 Re: .HPT to BIN
    then theres always for fun, close out everything, reboot the pc, try the bin again. never know. maybe make a small change to some thing, then save it.
  13. #33 Re: .HPT to BIN
    Nebraska
    Im looking at that too Scotty, no clue what to set for value tho.
  14. #34 Re: .HPT to BIN
    im Scott, lol and try zero? you can always change it back.
  15. #35 Re: .HPT to BIN
    Nebraska
    Lmao, sorry haven't had my coffee yet. Ill try that.
  16. #36 Re: .HPT to BIN
    Nebraska
    That would be awesome scotty! thanks! see if you can send your DB for tiny tuner I think im just lacking the right date base. That way if I ever need to use TT again.
    In my defense I got it right yesterday.
  17. #37 Re: .HPT to BIN
    seems you did. congrats on still having hair. this kinda bs will make you crazy.
  18. #38 Re: .HPT to BIN
    Nebraska
    lol. Already going bald so no big deal... No luck changing the value to 0 any more ideas?
  19. #39 Re: .HPT to BIN
    i hate to even say it, but maybe you need yet a older version of htp?
  20. #40 Re: .HPT to BIN
    Nebraska
    It works with 2.24, but i cant open and compare my old tune with it so i would have to start over and when I go from my truck to my car I have to uninstall then reinstall but I guess ill just have to deal.
