Thread: 2 different performance tunes
Results 1 to 9 of 9
  1. #1 2 different performance tunes
    Nov 2015
    seekonk, MA
    hello all. i am still new to this L67 style engine. i am a lsx guy usually. now, on my ws6 i can have 2 tunes in my pcm(by turning off the engine and flipping a switch) can the same be done with these pcms? I know my 99 has a perf shift button, and if i get a mail order tune the perf tune will only work with the button active. but what about the other "stock tune" can those parameters be changed? i am looking to run a daily tune, and a nitrous tune (same as my ws6) i tried the search function and only came up with 4 results none of which seemed to cover this, so I apologize if this has been covered multiple times.
    thanks in advance,
    Bruce
  2. #2 Re: 2 different performance tunes
    no it cant. the perf shift button only controls the shift of the tranny. you can make it more aggressive with higher shifts and make normal files less aggressive for when the perf shift is off.
    if you have mods even bolts on that it needs to be tuned for. why in the world would you want it to run on the crappy stock tune?
    these cars come with a crappy tune from gm.
  3. #3 Re: 2 different performance tunes
    Jun 2016
    Earth
    No, you cannot run two tunes and switch between them with a toggle switch.
    And technically you can't do that with your trans am computer either. You can only have one program ran on the computer at one time, without writing a tune to the vehicle, flipping a switch does nothing.
    I've seen people flip a switch to skew the IAT sensor to pull timing and prevent it from blowing up but that's a bad way to do things.
    Any of the tuners on the market be it HP Tuners or EFI live that can actually change every parameter inside the PCM has to do a either a full write or a calibration (partial) write to the computer to make any changes.
    There is no need to run two tunes either on a supercharged grand prix with no additional things like methanol or NOS. Just keep the performance shift button in all the time, it makes no difference on the engine side of things. It only changes the shift speed and shift pressure by a small amount. I maybe .100 or so of a second but I'd have to check again and it adds a few psi of line pressure.
  4. #4 Re: 2 different performance tunes
    May 2013
    RI
    Is this what you have in your LS1 for the dual flash pcm? (at the bottom)
    http://www.pcmcalibrators.net/
    Greg
    2004 GTP Special Edition
  5. #5 Re: 2 different performance tunes
    Jun 2016
    Earth
    Hmm, looks like it's for only select vehicles with the correct gen 3 computer in it already (512k - 1M). So a stock computer couldn't use a switch but one with a dual memory chip can, one can assume he bought that then.
    You couldn't do that with a 3800 PCM, totally different controller and is 5 times dumber computer than a LS based computer.
  6. #6 Re: 2 different performance tunes
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Just buy another pcm and keep it in the car. If for some reason you want to run another tune then turn it off, switch the pcms out, and have at it.
    I keep my backup pcm in the trunk at all times with a safe 93 tune on it vs my e85 tune I run most of the time. Gives me good piece of mind on longer trips.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  7. #7 Re: 2 different performance tunes
    Just curious....
    What would be different on your nitro tune that would effect daily driving? Thats mainly going to be in your WOT setting anyway right?
  8. #8 Re: 2 different performance tunes
    Nov 2015
    seekonk, MA
    Yes that is the pcm i have, didn't get it from them, but same idea. The reason for the separate nitrous tune is to pull timing... this was i can have the hottest tune possible around town, and when I flip that switch i have the best tune possible for the sizebshot of nitrous i am using. (150 shot currently in the t/a, but soon going up )
    -Bruce
  9. #9 Re: 2 different performance tunes
    hangover park IL
    that's easy, get an ICCU or just a happy knob (IAT potentiometer) and IAT vs timing table adjustment for pulling timing, you will want to zero out any iat vs afr tables
    ~James~ Psychotic Gearhead
  1. GXP Tunes Repository
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 05-12-2015, 09:00 PM
  2. DHP 1.0 Tunes
    By RivMan in forum PCM Tuning
    Last Post: 12-02-2012, 02:53 PM
  3. Lost my tunes!
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 10-13-2011, 11:18 PM
  4. E85 tunes
    By Hawkman in forum Midwest
    Last Post: 10-11-2011, 08:51 PM
  5. Tuners and Tunes
    By dakcornholio in forum PCM Tuning
    Last Post: 02-07-2011, 04:40 AM
