Thread: Transmission Change
Results 1 to 5 of 5
  1. #1 Transmission Change
    SE Level Member walkure's Avatar
    Aug 2011
    Puyallup, WA
    My stock gt trans is finally done after 245k miles. So I plan to swap to a spare gtp trans that I have sitting around the shop. I have HPTuners v3.0 and I believe that I only need to change the Drive Sprocket Ratio under the speedometer tab from 1.000 to 1.121. Is there anything that I need to change under the transmission tab? I am new to tuning and could use all the help I can get. Car is a '99 GP GT.
  2. #2 Re: Transmission Change
    Quincy, Mass
    Compare a your gt file to a gtp file and copy all the trans stuff over and the speedo might have other differences change whatever isn't the same
    No more GP 04 Impala SS Indy:
  3. #3 Re: Transmission Change
    Kemmerer, Wyoming
    there used to be a good guide on changing the transmission gear ratio using hp tuners that trannyman (TEP) made, but last time I looked for it, it was awol. I would do what swiggles suggested, and maybe send TEP an email and see if he has instructions on doing it
  4. #4 Re: Transmission Change
    Quincy, Mass
    The link I have for that isn't working anymore either.
  5. #5 Re: Transmission Change
    Aug 2011
    Puyallup, WA
    Thanks, I'll give that a try.
  1. Transmission cooler setup - should I change it? What temps are too hot?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2017, 08:25 AM
  2. Transmission Fluid and Filter change at 98k?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2015, 12:41 PM
  3. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  4. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
