BillBoost37 - I looked into the 98+ computer swap a little more. http://engine.firebirdv6.com/38pin.html That page gives a side by side view of F-Body PCM wiring changes from 95 to 02. It looks like the power, ground, and serial lines are the same pins but EVERYTHING else is different. With that much work involved to re-pin the connectors, I'm thinking the 97 PCM is the way to go unless some very compelling reasons come up to do the 98+ swap.
Fivefingerdeathpunch - Good to see you here!
Scottydoggs - Interesting that you are seeing the 4 gears in a manual trans tune. I will be getting my AVT box this weekend, so I'll be able to start playing with the DHP software and I'm sure I'll have more questions as I start to get my feet wet. The first thing I'll do is read the stock 1996 bin and I'll post it here.
