if the camaro has a pcm in it, use that one. and your gonna have to make the camaro bin into a sc bin. cause theres no l67 camaro's made.
with dhp you open the camaro bin file and a 97 gtp bin side by side, then copy all the files over, with dhp its as easy and dragging the file from one bin to the other. use tiny tuner to make a supercharger present.
if your running a ic with the turbo you can run 10 psi easy. maybe more.
