Thread: Torque pro ap question
Results 1 to 12 of 12
  1. #1 Torque pro ap question
    Mar 2016
    Toledo oh.
    Hey guys, I just got an obd reciever and downloaded the torque pro ap on my android. I am trying to go thru and get the ap set up and I cannot seem to find KR in any of the choices. I found a timing advance option but I thought there was one just for KR. Can you guys help?
  2. #2 Re: Torque pro ap question
    its listed as knock retard. if you dont see it in the list, d/l torque scan its a free add on. it should show then.
  3. #3 Re: Torque pro ap question
    SE Level Member Hot wheels's Avatar
    Feb 2015
    Breckenridge TX
    Go to your torque pro app. Then press settings on the main screen. Then select ADD PREDEFINED SET and then select Pontiac/GM/Opel/Vauhall. This will add the parameters for GM to you car.now go to the main menu on the App and access the real time Data page. Press and hold on an empty spot. Select ADD display select digital display select knock retard. Now you can monitor knock in real time
  4. #4 Re: Torque pro ap question
    False, Torque scan has nothing to do with the extra PIDs.
  5. #5 Re: Torque pro ap question
    it was missing in my set up, did t/s and it showed up. i had pids all loaded up first. then got the t/s. t/s adds a load of other cool things to scan too. its free and worth getting.
  6. #6 Re: Torque pro ap question
    Donating Users moddman's Avatar
    Midwest
    X2 What Scott said. Its a FREE add-on called Knock Detector from Google Play. https://play.google.com/store/apps/d...kills.kd&hl=en
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  7. #7 Re: Torque pro ap question
  8. #8 Re: Torque pro ap question
    GXP Level Member
    Mar 2015
    Tomball
    I just used the one that comes I with the GM PIDs.
  9. #9 Re: Torque pro ap question
    Mar 2016
    Toledo oh.
    Thanks alot guys. I ended up having to download torque scan as scottydogg suggested. I messed with it for quite awhile and wasn't able to get it. But I used the link and now I can monitor KR. Thank you for the help
  10. #10 Re: Torque pro ap question
    Mar 2016
    Toledo oh.
    Ok guys I'm having problems with my torque app still. It works like a champ on my wife's gmc terrain, everything seems to work exactly how it's supposed to. But when I try to use it on my 02 gtp it works for about 10 seconds and then quits responding. I've tried adjust a few settings within the ap to help communication but nothing seems to help. If I pull out the reciever and plug it back in, same thing, works for a few seconds and quits. Any advice? It works great on my wife's vehicle.....
  11. #11 Re: Torque pro ap question
    GXP Level Member
    Mar 2015
    Tomball
    Did you set up a profile for your vehicle separate from your wife's profile?
  12. #12 Re: Torque pro ap question
    Mar 2016
    Toledo oh.
    Yes
  1. Torque converter question
    By m17davis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2015, 02:26 PM
  2. torque pro question
    Last Post: 07-30-2014, 09:52 PM
  3. Question about logging with torque app
    By K Kraziee in forum General Tech Discussion
    Last Post: 05-24-2014, 08:53 AM
  4. Torque Question
    By ajoliver2010 in forum Brakes/Suspension/Chassis
    Last Post: 08-20-2012, 11:30 AM
  5. stupid question about torque
    By e6600 in forum General Tech Discussion
    Last Post: 10-27-2010, 02:29 PM
