Thread: stupid question about torque
Results 1 to 5 of 5
  1. #1 stupid question about torque
    SE Level Member e6600's Avatar
    Los Angeles
    so lets just say if i preferred torque over hp, what would i need to do instead? while still making respectable whp
    instead of headers, plog/pems, dp, vs cam?
    98 grand prix gtp: stock until i fix problems
  2. #2 Re: stupid question about torque
    they go hand in hand with one another. youll always make more torque than horsepower just because of how this motor runs, especially if you stick with the m90.
  3. #3 Re: stupid question about torque
    GT Level Member starscream5000's Avatar
    Kentucky
    Where do you like your torque? Low end? High end?
    A low lift cam will have more torque in the bottom end, but fall on it's face in the upper RPMs. A higher lift cam will be boring in lower RPMs, but scream up top.
    A supercharger will usually deliver more torque on the bottom end, but a small turbo will as well. A bigger turbo, such as a GT35R will deliver a big punch up top.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  4. #4 Re: stupid question about torque
    HUDSON
    Well, you cannot have HP without TORQUE, HP is a calculated number by a certain amount of TQ at a given RPM. HP=TQxRPM (5252). SO as you can see as TQ rises, so does HP. Build for TQ in the RPM range you want the engine to operate in, HP will follow. I really wish the indistry would just give TQ@ RPM numbers.
    Low and mid range torque make a car fun to drive on the streets, high rpm torque makes a car fast on the top end and at the racetrack. Smaller intake and exhaust make more low and mid range tq, making them larger moves the power up in the RPM band, thats why factory cams and exhaust are small.
  5. #5 Re: stupid question about torque
    Apr 2009
    stockton ca
    just run a cam with dp and pems and you will make plenty of torque my set up numbers are in my sig
  1. Stupid PCM question
    By Cail in forum General Tech Discussion
    Last Post: 09-12-2010, 05:02 PM
  2. Stupid Question - Torque Stars
    By Sheepdog in forum Tires & Wheels
    Last Post: 09-06-2009, 10:52 PM
  3. Stupid Question
    By Tyler_06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2009, 01:23 AM
  4. Stupid Question time, What is this?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 07:22 PM
  5. Potentially stupid question...
    By bentendo92 in forum Off Topic Discussion
    Last Post: 08-03-2008, 12:23 PM
