Thread: 2004+ GTP injector tables
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: 2004+ GTP injector tables
    Bastard Reptile's Avatar
    Kansas City, MO
    Well, it's the same in HPT also....only thing I can guess is that it's for vacuum. Most of the driving is like that anyway, but the 97-03 tables are only half of that, more simple I guess.
  2. #22 Re: 2004+ GTP injector tables
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Reptile View Post
    If you're ever in DHP, you multiply the stock injector tables by 78.5% and boom.
    Ok, I'm really new to this, but this doesn't seem right to me. Help me understand what I'm missing here.
    (My math says %77.65 btw)
    BUT if I multiply the IFR by %77.65 (scaling down the IFR) the car won't even stay running for more than a few seconds, sounds like it's starving for fuel.
    However If I multiply the IFR by the inverse (%128.78) then my trims are good and no more P0171.
    7"
  3. #23 Re: 2004+ GTP injector tables
    GXP Level Member
    Mar 2015
    Tomball
    It appears that Reptile used 33/42 (78.5714%) instead of 42.5. I get the same thing you got using 33/42.5 (77.6470%). So what you are doing is taking 42.5/33= 1.2878 or 128.78%?
    Jeff
  4. #24 Re: 2004+ GTP injector tables
    Oct 2011
    Toledo, OH
    Quote Originally Posted by J57ltr View Post
    Jeff
    Yes, exactly. I was using 42.5 but my injectors are in fact 42s so his math was right and yes in DHP I have to scale the IFR by %127 instead of %77 in order for the car to run.
    7"
  5. #25 Re: 2004+ GTP injector tables
    GXP Level Member
    Mar 2015
    Tomball
    So for 60's it's going to be 181.82%. I guess now I just need to figure out what I need to change in DHP to go E85.
    Jeff
  6. #26 Re: 2004+ GTP injector tables
    Oct 2011
    Toledo, OH
    Jeff
    Under Fuel, set Injector_Skew_Percent to 125 for winter or 130 for summer. I set mine for 127.5.
    To get deeper into the IFR non-issue, DHP's IFR table is for "milliseconds per gram" so theoretically you'd lower the numbers with bigger injectors because it would take LESS milliseconds to spray one gram of fuel. And there is for sure a number of people here that LOWERing the mSec/Gram worked like it should. Not sure if DHP version makes a difference or anything.
    7"
  7. #27 Re: 2004+ GTP injector tables
    Oct 2011
    Toledo, OH
    2004+ GTP injector tables Attached Images
    7"
  8. #28 Re: 2004+ GTP injector tables
    Kansas City, MO
    I honestly don't remember why I had to do what I did at the time. Good job on figuring it out though.
  9. #29 Re: 2004+ GTP injector tables
    GXP Level Member
    Mar 2015
    Tomball
    Man this has me confused as I read this a while back. I wonder if it's just off for the 04+ cars.
    http://www.grandprixforums.net/threa...les-for-DHP-PT
    Jeff
  10. #30 Re: 2004+ GTP injector tables
    GXP Level Member
    Mar 2015
    Tomball
    That skew did nothing for my car. I changed it to 127.5%, 130% and 134.5% and back to 100% and it made absolutely no difference at all. I ended up changing the IFR table by 27.5% and it was too lean then added 30% and that was still too lean, then changed it to 34.5% and it's perfect. I don't think the Skew changes anything on my 05' for some reason.
    Jeff
  1. IAC tables for N*
    By TEK310 in forum PCM Tuning
    Last Post: 02-24-2014, 01:57 PM
  2. Tables! What tables!
    By Frosty in forum PCM Tuning
    Last Post: 12-13-2012, 02:57 PM
  3. 2 LQ4 MAF tables?
    By Pure2sin in forum PCM Tuning
    Last Post: 11-17-2011, 11:56 PM
  4. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  5. LT1 Maf tables
    By FoSHO99 in forum General Tech Discussion
    Last Post: 04-21-2009, 01:11 PM
