Thread: BIN file for 04 Comp G top-swapped and cat delete
Results 1 to 4 of 4
  1. #1 BIN file for 04 Comp G top-swapped and cat delete
    Jun 2012
    Cold Spring, MN
    Anyone have a known good, BIN file for an 04 Comp G with a top-swap and cat delete (not just the codes, but the cat test mapping deleted from the file)?
    I did a top-swap along with a ZZP catted DP but am getting tired of this fuel dumping I get that's killing my fuel economy.
    It doesn't have to be perfect file, but if the mapping for the cat test/faulty rear o2 can is eliminated I can tune from there for the top-swap.
    Thanks in advance.
  2. #2 Re: BIN file for 04 Comp G top-swapped and cat delete
    May 2008
    Schuyler, NE
    In my version of Tiny Tuner, I don't have the ability to turn off the cat test for an 04+ car. At least on the 04 comp g file I have.
    Either my version is too old, or the 04+ cars were never mapped out to remove the cat test.
  3. #3 Re: BIN file for 04 Comp G top-swapped and cat delete
    what you mean comp g top swap? you mean its bottom swapped now? you lower your timing 2 degrees wot if thats the case.
    ill getting a bin file now, ill check it on my vs of tt.
  4. #4 Re: BIN file for 04 Comp G top-swapped and cat delete
    im not seeing anything for the cat test at all.
  1. Can I delete traction control in the pcm file?
    By buck531 in forum PCM Tuning
    Last Post: 10-18-2015, 06:05 PM
  2. Top Swapped L26 hpt file
    By jlgp2007nc in forum PCM Tuning
    Last Post: 04-26-2013, 02:42 PM
  3. need dhp bin file
    By nascartech in forum PCM Tuning
    Last Post: 11-20-2010, 11:50 PM
  4. Transmission bin file to another bin file?
    By Pure2sin in forum General Tech Discussion
    Last Post: 11-10-2010, 07:11 PM
  5. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
