Thread: Tune help
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Tune help
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    I have been fighting with my 05 GTP trying to tune out some KR, and unsure if I am running out of injector or if there is something else I should be looking at. Car was originally tuned at a local dyno shop and didn't have any KR but was running pretty rich. About a week later I started seeing 3-4* at WOT with the same tune, still not ruling out that it could be false KR. I should also mention the car was originally tuned on a 3.5" SC Pulley but I have since gone to a 3.6" pulley which has made no difference in the KR department. I should also mention my AFR when the car was tuned locally was 11.3-11.5 and that has not changed.
    Any assistance would be greatly appreciated!
    https://drive.google.com/file/d/0B3y...ew?usp=sharing
    '05 GTP - E85 - XP Cam - 3.0 Pulley - Supporting Mods...
  2. #2 Re: Tune help
    GXP Level Member
    Mar 2015
    Tomball
    Subbed.
  3. #3 Re: Tune help
    Do you have a wideband to confirm that this AFR has not changed?
  4. #4 Re: Tune help
    Donating Users timboku's Avatar
    Montgomery, IL
    What is your WOT fuel trims at, and yes Don you have a wideband? Any ses light on? What gas you run?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: Tune help
    Mar 2015
    Appleton, WI
    LTFTs lock in to -1.6 at WOT - I do not have my wideband installed yet, but like i had mentioned my fueling/MAF settings have not changed since the dyno. No SES lights, running 93 pump gas (Shell if that matters) I have linked my most recent scan from HPTuners below
  6. #6 Re: Tune help
    Montgomery, IL
    Gas blend changes from summer to winter which can effect things
  7. #7 Re: Tune help
    Mar 2015
    Appleton, WI
    Could it be that my trans dipstick is knocking against my headers causing false KR ?
  8. #8 Re: Tune help
    May 2008
    Schuyler, NE
    You need to get your wideband installed, otherwise you can't tell if your afr has changed.
    The easiest way to rule out false kr, is to fill up with race gas.
  9. #9 Re: Tune help
    Mar 2015
    Appleton, WI
    I did throw a couple of octane boosters in and saw no difference in KR still the 3-4* I will hopefully get the wideband installed in a couple of months
  10. #10 Re: Tune help
    Kemmerer, Wyoming
    Quote Originally Posted by kewGTP View Post
    octane boosters don't work
  11. #11 Re: Tune help
    May 2008
    Schuyler, NE
    Quote Originally Posted by SgtMarshal View Post
    This. Don't waste your money on them. Buy some 110 octane race gas.
  12. #12 Re: Tune help
    your sig says hp tuners. take a degree of timing out of the wot cells.
  13. #13 Re: Tune help
    Mar 2015
    Appleton, WI
    I will pull some timing and see what changes happen
  14. #14 Re: Tune help
    E85 is fun, too.
  15. #15 Re: Tune help
    Mar 2015
    Appleton, WI
    Quote Originally Posted by blueguy View Post
    E85 is fun, too.
    I will be going XP cam/E85 in spring, but until then just trying to sort out my KR. I will report back this weekend when I have a chance to drop some timing
  16. #16 Re: Tune help
    Mar 2015
    Appleton, WI
    Pulled 3* or Timing from WOT cells - no change, I will try some race gas, but i am almost convinced it is false KR caused by my trans dipstick hitting the crossover on my ZZP headers
  17. #17 Re: Tune help
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    bend your dipstick?
  18. #18 Re: Tune help
    Mar 2015
    Appleton, WI
    It was when installed, but I still hear a rattling coming from the exhaust at mid range rpms, I cant see anything else that would be causing a rattle
  19. #19 Re: Tune help
    SE Level Member charlieRobinson's Avatar
    May 2014
    OH
    Are you scanning? Can you post a screen shot of the KR?
    1999 Buick Riviera - L67
    PLX wideband +HPT pro +X-P HOT cam, 140#springs, 2x chain, LS7 lifted
    ZZP SS Headers + 3" Downpipe + 200 Cell Cat.+ Aero Resonator
    Gen V swapped L67, 60# injectors, E85, N*&LQ4MAF
  20. #20 Re: Tune help
    Mar 2015
    Appleton, WI
    Thats a export from the log file.
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. PCM Tune
    By csssaint12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2010, 08:32 PM
  5. Tune up?
    By Lucid Violence in forum General Tech Discussion
    Last Post: 07-22-2010, 11:18 AM
