Thread: HPTuners 3.0
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 84
  1. #41 Re: HPTuners 3.0
    Quote Originally Posted by 2004l67 View Post
    So to anyone else fighting this, I've found it is a bug in scanner 3.0. I've got a ticket open with them now.
    http://www.hptuners.com/forum/showth...ight=math+axis
    Did you ever get anywhere on this? I saw that there was an issue with it and an apparent fix. So I re downloaded it (thinking the newer one would solve the issue) with no luck. I'm having the same issue you are. Cant get my KR to log properly (among other things... apparently my WB doesn't want to either) so it is halting my progress.
    Ive just been doing the ol look at WB, maf hz and KR all at once and making little adjustments here and there.
  2. #42 Re: HPTuners 3.0
    Mar 2015
    USA
    The issue I was having (airflow column not updating) did finally get fixed.
    Make sure everything you are charting is backed up by a "channel".
    Are you running the WB in via egr or the pro interface? It was a little tricky reading it via egr but I finally got it. I'll try try post my config tonight for ya.
  3. #43 Re: HPTuners 3.0
    A config would be awesome. Im using the interface and have read the thread twice on setting it up. Ill double check my channels though too as I had to start from scratch and may have overlooked something.
    Cheers
  4. #44 Re: HPTuners 3.0
    GTP Level Member
    Jan 2015
    Lincoln, NE
    How are you guys logging cylinder airmass it's not a channel you can log. The math parameter for it doesn't work correctly for me either
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  5. #45 Re: HPTuners 3.0
    2004 got it to work somehow I was waiting for him to post a config because Im stumped as well....
  6. #46 Re: HPTuners 3.0
    GTP Level Member
    Jan 2015
    Lincoln, NE
    anything new on this front?
  7. #47 Re: HPTuners 3.0
    Kemmerer, Wyoming
    I checked the HP Tuners forum yesterday, and it seems they are getting some of the bugs worked out with new updates. I was able to log wideband data through my a/d input, as well as through the serial input, although the refresh rate is so fast, so the fluctuation is pretty high as compared to what the actual wideband gauge is displaying.
    One thing I noticed that was a bit annoying was that I was not able to add Injector Duty Cycle to the channels, only IPW is available.
    edit: on further research, I found that duty cycle is calculated using IPW and rpm, so I added IPW and the duty cycle started working on the chart.
  8. #48 Re: HPTuners 3.0
    SE Level Member chibiblacksheep's Avatar
    Southeast, PA
    Did anyone get a config file for the L36/L67? I'm trying to get my KR histogram working, but having that issue with the cylinder airmass (g) as well.
    CSC Powered 2000 Monte Carlo SS
    2013 Camaro 1LS
  9. #49 Re: HPTuners 3.0
    Quote Originally Posted by chibiblacksheep View Post
    Still waiting on this as well... last I heard HP was working on it for the next update.
  10. #50 Re: HPTuners 3.0
    Southeast, PA
    I asked for help on the HPTuners forum and someone was able to create me a retard graph that works the way that I wanted.
    If you go here and download the layout, you should see it.
    http://www.hptuners.com/forum/showth...for-v3-scanner
    2013 Camaro 1LS
  11. #51 Re: HPTuners 3.0
    Quincy, Mass
    .bins are no longer supported and they have no plans to add them back in, i emailed them about it..
    No more GP 04 Impala SS Indy:
  12. #52 Re: HPTuners 3.0
    May 2008
    Schuyler, NE
    Those *****es
  13. #53 Re: HPTuners 3.0
    May 2008
    Schuyler, NE
    We need Charles to get his new tuner out.
  14. #54 Re: HPTuners 3.0
    Mar 2014
    Tucson
    Got a "Validate Checksum Failed" yesterday when I tried to read an already tuned PCM.
    I guess they're working on it.
  15. #55 Re: HPTuners 3.0
    Kemmerer, Wyoming
    I keep hearing whispers to be patient from aaron decker. I wonder if aaron coordinated with charles to get another tuner in the works.
  16. #56 Re: HPTuners 3.0
    Quincy, Mass
    i tried to write with 3.0 and it messed up the pcm temporarily. car wouldnt start and hpt couldnt read or write car wouldnt even try to start. used my spare pcm for a few days and then tried the original again and car started right up. then i used 2.5 to read and write and have had no issues.
  17. #57 Re: HPTuners 3.0
    Im probably just going to redownload the 2.5 then. I honestly dont necessarily need my scanner anymore anyway. Its just nice to have readily available.
    I have gauges for anything I rally need (AFR,Maf and KR) and have had the same setup for about 2 years now.
  18. #58 Re: HPTuners 3.0
    Mar 2014
    Tucson
    Quote Originally Posted by BrandonHall10 View Post
    Upgraded to 3.0.126 All is well now.
  19. #59 Re: HPTuners 3.0
    Quincy, Mass
    I emailed them about a different issue and they release me 3.1 still have to test the read and write and there were 2 errors i emailed them about too.
  20. #60 Re: HPTuners 3.0
    Quincy, Mass
    But the scanner is much better now with 3.1, ran a log file through and the retard histogram things were filling in all the boxes
  1. WTB: HPTuners
    By ADrugDealer in forum Wanted To Buy - Parts
    Last Post: 09-27-2015, 10:20 AM
  2. Wtb hptuners
    By kuntzie in forum Wanted To Buy - Parts
    Last Post: 11-02-2014, 06:42 PM
  3. WTT: HPTuners for HPTuners Pro
    By Explicit_Spade in forum Wanted To Trade
    Last Post: 05-06-2014, 03:34 AM
