Thread: DHP Powrtuner severity 66 error -fixable?
Results 1 to 20 of 21
  1. #1 DHP Powrtuner severity 66 error -fixable?
    recently got error 66 Database Error Unable to Init AC List whenever i open up the program the small error window comes up. is there a fix or how to repair this issue? this is even before connecting the powrtuner to the car. i am currently trying to just do some editing on my bin file. TIA
  2. #2 Re: DHP Powrtuner severity 66 error -fixable?
    I'd remove the program and reinstall.
    Do you need another link to dropbox?
  3. #3 Re: DHP Powrtuner severity 66 error -fixable?
    bill, what do you mean if i need another link for a dropbox? you mean a copy of the powrtuner software? i are confused lol.
  4. #4 Re: DHP Powrtuner severity 66 error -fixable?
    Yup.. remove, reload. If you need the software, holler
  5. #5 Re: DHP Powrtuner severity 66 error -fixable?
    ah gotcha. i'll let you know bill, much obliged.
  6. #6 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    Guys,
    I have this error with my PT, and I have uninstalled, but to no avail.
    Please let me know if there is a fix.
    Thanks,
    Nick
  7. #7 Re: DHP Powrtuner severity 66 error -fixable?
    you install the data base in the dhp folder? then select use data base?
  8. #8 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    Yeah I executed the registry file then grabbed the dbf and put it into the program directory yeah
    Sent from my SM-G935T using Tapatalk
  9. #9 Re: DHP Powrtuner severity 66 error -fixable?
    is this the first time using it? has the cable been registered yet?
  10. #10 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    Yeah I have been using it for 5 days. Yesterday I flashed for probably the 8th time and it was interrupted, then I went into recovery and it reflashed successfully. I then edited another file and tried to flash today, but had to do the same thing, going into recovery... Now it won't even open after several reinstalls
  11. #11 Re: DHP Powrtuner severity 66 error -fixable?
    what year car you working on?
  12. #12 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
  13. #13 Re: DHP Powrtuner severity 66 error -fixable?
    you pulling the radio fuse when flashing it?
    your best off building a off board. much safer that way for 04 up cars.
  14. #14 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    No I didnt. But there were no issues for several flashes. I am still open to any ideas on how to fix the problem.... There has to be something else that corrupted which doesn't get uninstalled with powrtuners. I'll try uninstalling MDAC and . Net framework, as well as all other programs
  15. #15 Re: DHP Powrtuner severity 66 error -fixable?
    if you didnt have dot net 1.1 installed it wont work at all. its the radio fuse. pull it then flash it. dhp dont like the 04 05 cars much, it can be a tad clitchy, why a off board is best. you bypass the cars BS and flash right to the pcm.
  16. #16 Re: DHP Powrtuner severity 66 error -fixable?
    and if you have a check engine light lit up for some reason, it dont like flashing to it. or reading ive found.
  17. #17 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    Alright I uninstalled everything, deleted the reg file, and reinstalled everything. Still getting the error
  18. #18 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    Alright guys I figured out the solution without just using a different laptop - you just gotta add a new user on ur laptop and use that user to open powrtuners.
  19. #19 Re: DHP Powrtuner severity 66 error -fixable?
    or try right clicking the icon to open powertuner and click run as admen
  20. #20 Re: DHP Powrtuner severity 66 error -fixable?
    Jan 2014
    United States
    Dude,
    I wish you had known that was a solution 3 days ago... Running it as administrator also works. I don't know why it needed to be run as admin all of a sudden, but whatever, we're good now. 👌
  1. Item Found, Please Delete
    By JEBSR in forum Wanted To Buy - Parts
    Last Post: 05-02-2014, 09:21 PM
  2. Strut busted through the frame in trunk...fixable?!
    By chicagosleeper in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2014, 08:50 PM
  3. Coolant elbow leak...is it fixable???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2010, 11:29 PM
  4. This is a good one! Fixable??
    By x1FastGTPx in forum Forum Bugs/Suggestions
    Last Post: 02-22-2008, 11:46 AM
