Thread: How much KR does it take to chip a piston?
Results 1 to 9 of 9
  1. #1 How much KR does it take to chip a piston?
    Dec 2013
    ohio
    Recently switched to 2.6 pulley. Never had any KR until now. From first to second I'm seeing 2.0 and from second to third 3.2 How much danger am I putting the engine in? I think shift points may be too high but it really screams or whines (loudly) now and I kind of like that
  2. #2 Re: How much KR does it take to chip a piston?
    pulley up or pay up.
  3. #3 Re: How much KR does it take to chip a piston?
    the more boost you're running, the more heat you're creating, the more likely that minimal detonation will do damage.
  4. #4 Re: How much KR does it take to chip a piston?
    There is no set number as you are gathering from the posts above this one.. Sometimes it happens..sometimes it doesn't. Reality is.. if you constantly see knock you'll end up on the low octane table and all you are doing is robbing power.
  5. #5 Re: How much KR does it take to chip a piston?
    Yeah, think of the heat and pressure you are making with that 2.6. I'm sure you are either maxing or nearly maxing the stock map sensors at 14.7 psi. You are riding a fine line for sure. I'd go back to a 2.8 pulley.
  6. #6 Re: How much KR does it take to chip a piston?
    Buffalo
    Is that extra boost worth the timing penalty AND potential piston damage?
  7. #7 Re: How much KR does it take to chip a piston?
    Sep 2015
    flint
    Biggest reason pistons break from kr is because lower timing puts more heat into the piston and weakens it, and sticks it in the bore to the point of breaking off the ring land.
    Doesnt run 9s
  8. #8 Re: How much KR does it take to chip a piston?
    Dec 2013
    ohio
    I know it's not maxing out the MAF running N* with LQ4 MAF and also running FSIC. Before I pulley back up I have water meth injection I need to get working again and as I said shift points are set real high. I read where someone got rid of a little KR by adjusting shift points 200 RPM or so. I was thinking 2-3 degrees KR was nominal.
  9. #9 Re: How much KR does it take to chip a piston?
    hangover park IL
    from what i can figure, its not how much, its total cycles, with cycle count inverse to kr amplitude
    the aluminum pistons are fine, but focused high pressure waves from preignition/too much timing stresses the pistons typically near the 12-2 o'clock position. and aluminum does not take to repeated stresses without work hardening and crack propagation.
    while i feel that chamber design does seem to focus the pressures to (at the least) the inboard side of the piston, the adding factor is that area being right next to the intake valve where it also contributes to thermal cycling of that area as its washed with liquid/vaporized fuel at each intake event.
    the thing is that aside from metallurgy/tooling of the pistons, and the usual results of unicorns and knock lobsters due to parts bin lottery of assembly line production. you looking at it being just as bad to have low levels of knock over a long time as it is to have high levels for a short time.
    with the sc setups having such short fuel vaporization time (injector quite close to valve) id hazard a guess that even a partially streaming injector would screw with fueling. ive found just the fuel rail positioning can change fueling. i now try to lay my injectors over farther/higher angle, to shoot towards the inside wall.
    while it took the riv's non bbv'd whipple and 150lbhr's to find this damned issue at lower rpm's it'd hold true for a smaller injector/air volume even if its to a lesser degree....(along with finding out the fuel rail pressure fluctuations are a real thing, and do affect adjacent cylinder fueling)
    test ****. make one change and test. hell just rotating the maf on most air intakes will change the fueling and sensitivity.
    not all improvements are wholly electronic table modifications, some can be quite simple as making sure you assemble parts consistently....
    then again if i had been consistent, we probably wouldnt have found the riv's odd changes in idle quality/tune with just small changes in assembly
    craploads of things are interrelated but keeping detonation counts at zero should be everyones goal since you can mostly look at chipping a piston being accumulative knock.
    build it for efficient flow and you likely wont get knock, even when lean
    ah who am i kiddin, i just shake up my magic 8 ball and make my life's choices
    ~James~ Psychotic Gearhead
  1. Might be looking for 1 l67 piston and rod
    By gbgn1 in forum Wanted To Buy - Parts
    Last Post: 04-14-2015, 01:39 PM
  2. Replies: 4
    Last Post: 01-04-2015, 11:58 PM
  3. clutch piston?
    By murp9302 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 10:53 PM
