Thread: Digital HP Tuners registering different cable.
Results 1 to 9 of 9
  1. #1 Digital HP Tuners registering different cable.
    Aug 2014
    Milwaukee
    One of my friends let me barrow his DHP tuner. I downloaded the DHP software from Dropbox along with .Net Framework 1.1. I have some pictures on my current setup. The different cable is the silver one with blue connectors. its a serial to usb cable. Number 2303 on cable. The problem I am having is when I open PowerTuner it wants to register the cable. I have tried all 16 COM ports and buad Rates. Also tried all 3 USB ports on laptop. And every time it shows up unable to communicate. When I go into Device manager I get a Code 10 error for not enough data on the cable and it is currently up to date. When I talk to my Friend he says I need to find a driver that will let my computer connect/recognize the cable. My computer is running windows 8
    Digital HP Tuners registering different cable. Attached Images
  2. #2 Re: Digital HP Tuners registering different cable.
    Dec 2013
    ohio
    Ditto but running windows 10. Messed around about half hour on it tonight and I'm scratching my head on this one but not a big computer guy. I was just about to start the same thread.
  3. #3 Re: Digital HP Tuners registering different cable.
    you need the driver for the adapter cable you are using from usb to serial
    Guy 2.. you need to use a compatibility mode.
  4. #4 Re: Digital HP Tuners registering different cable.
    Sep 2015
    flint
    if you are still having problems, there is a bad rash of cables that look like that , that flat out dont work.
    Doesnt run 9s
  5. #5 Re: Digital HP Tuners registering different cable.
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Keyspan or GTFO
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  6. #6 Re: Digital HP Tuners registering different cable.
    hangover park IL
    keyspan, as above. those cheapo serial/usb's seem to be hit or miss depending on how far away from quota they were at the time in china. and even then DHP dont like em
    ~James~ Psychotic Gearhead
  7. #7 Re: Digital HP Tuners registering different cable.
    Aug 2014
    Milwaukee
    So is there a spacfic cable i need to get from keyspan? and part Numbers? This would be replacing the silver cord correct?
    I found this
    http://www.tripplite.com/high-speed-...yspan~USA19HS/
  8. #8 Re: Digital HP Tuners registering different cable.
    Aug 2014
    Milwaukee
    Or if anyone knows the right driver?
  9. #9 Re: Digital HP Tuners registering different cable.
    Quote Originally Posted by cmoris12 View Post
    I found this
    the key span is what i have, they have drivers on their site there. you pick the one that matches your os in your pc. driver for a USA-19HS
    you would also need a normal serial cable from the dhp to the keyspan. then the usb from the keyspan to the laptop.
  1. help registering dhp
    By mike kulp in forum PCM Tuning
    Last Post: 09-05-2014, 05:50 PM
  2. Abs cable
    By jc71corvette2 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 03:23 PM
  3. Digital Driver Information Center and Digital Climate Control
    By uNda6gT in forum Visual/Body Modifications
    Last Post: 03-28-2012, 10:47 PM
  4. Will a digital heater control work in a car without the digital?
    By Roanokegprix in forum General Tech Discussion
    Last Post: 11-05-2010, 08:04 AM
  5. 97-03 Digital DIC & Digital HVAC Swap Question
    By StreetChariot in forum General Tech Discussion
    Last Post: 03-27-2008, 11:04 AM
