Thread: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
Results 1 to 20 of 78
  1. #1 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    hangover park IL
    Quote Originally Posted by ItHurtz View Post
    ok then I will stick my maf in a giant tube then, yay me
    you can either scale it mechanically by allowing for a larger sample volume than OEM, or you can scale it with a frequency reduction
    Quote Originally Posted by 2003 SSEi View Post
    Id rather have the L67 with a Gen V than the L32. There is really no advantage to the L32 aside from the SLIGHTLY and I mean slightly better heads, actually many consider it a downgrade given the connecting rod design
    heads are not really any better, just a new series of molds went online so your less likely to get a reworked mold head that has massive core shift, remember those head molds for the casting sand were in use from 93+ (first SII 3800 being in the 94 model year) so by 00+ they were pretty beatup.
    an early mold 7 is a great head, a 99/00 mold 7 has nearly 1/4" core shift on the one end cylinder. the valves weren't better, just cheaper, same with the rods..... thanks bean counters.
    Quote Originally Posted by SgtMarshal View Post
    L32 rods and pistons are better than L67
    pistons yeah, better anodizing and the skirt coating (that wears away quickly anyways), the rods were just cheaper to make/machine. Powdered metal forging is not stronger than cast, just more brittle.
    its the only way that the fractured cap technology works...is by engineering a brittle rod that's barely a step above sintered metal construction.
    ive seen thrown rod L36's where you have the cap/rod twisted into damn near a pretzel with the block/bore/pan/skirt thoroughly ****ed....you look at a thrown rod L26 and you find the rod in 8-400 pieces and barely a mark on the block...
    ive seen this enough times that I don't like the PM stuff....at all
    ^^ your drunk, L67 or bust
    id rather find the L67/32 (steel pan L32's) that have the L67 cast rods with the L32 pistons/front cover
    ~James~ Psychotic Gearhead
  2. #2 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    The FelPro ones that came with my kit are a hard black plastic with blue o-ring style gasket, no metal at all. Does anyone have the part# for the FelPro metal style?
  1. Subaru BRZ vs........ Land Yacht
    By BillBoost37 in forum Track Sessions and Kills
    Last Post: 10-10-2014, 11:30 AM
  2. The following was admitted by a subaru owner...
    By Chad Gervais in forum Off Topic Discussion
    Last Post: 08-24-2012, 04:25 PM
  3. 2003 Subaru
    By Ballin00gtp in forum Members Rides
    Last Post: 11-10-2011, 10:02 AM
  4. Subaru WRX 04
    By GAFF in forum Track Sessions and Kills
    Last Post: 04-08-2011, 01:40 PM
  5. GTP vs Subaru
    By Nickell in forum Track Sessions and Kills
    Last Post: 11-09-2009, 02:37 AM
