Thread: Project LQ4 - V8 S10 - Sold.
Page 17 of 66 FirstFirst ... 7151617181927 ... LastLast
Results 321 to 340 of 1306
  1. #321 Re: Project LQ4 - Poor white S10
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by BrandonHall10 View Post
    I lol'd.
    It sure is a mouthful, and no vowels, so you cant make it sound like a word. Maybe that's the barfing sound?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  2. #322 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Let's just go with "tank"
  3. #323 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Think I may have found a way to keep the factory oil cooler with the conversion headers. The hard lines on the factory adaptor block hit the headers, which obviously won't work. Originally I was just going to use the bypass plate that came with the conversion pan, but the more I thought about it, the more I like the idea of having a functional oil cooler. Especially living out here in the southwest.
    I came up with a plan to just cut the hardline where it's still vertical and splice in some rubber trans cooler line. Then tie back into the rubber section of the factory lines further forward. Fab up a bracket to hold them away from the headers with my new welder and call it a day. I didn't like the idea of trusting my oiling system to hose clamps, but I didn't see any other economical option. Until I found this:
    Looks like for around $120 total, I'll be able to run 100% AN fittings and braided hose from the engine to the cooler in the radiator. No rubber hose, no hose clamps. Now, AN fittings and lines don't really fit the budget theme of the truck, but I think for something as important as the oiling system, it's money well spent.
  4. #324 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Here's the results of yesterdays cleaning
    Came out pretty good. The black on the frame there is what's left of the undercoating. I think the oil ate the rest of it.
  5. #325 Re: Project LQ4 - Poor white S10
    my 03 gmc the oil cooler lines ran right down the lip of the oil pan from the filter and came out straight under the balancer. cant see how they could be in the way of any thing.
    i only know this because i had to replace one, belt blew off and i never noticed the belt knocked the line out of its clip and it rode the balancer and cut it.
  6. #326 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    No, you're right. That parts all true. What you're forgetting is the big loop they put in the lines to clear the block heater.
    That, combined with the fact that the headers hug the block much more than the stock manifolds cause the issue
  7. #327 Re: Project LQ4 - Poor white S10
    well then...
    on a side note, the cooler and lines hold about 3 quarts of oil. so have like 9 quarts on hand to fill it up the first time. also learned this the hard way lol
  8. #328 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Haha! Probably more. The pan and pickup are new and thus bone dry.
  9. #329 Re: Project LQ4 - Poor white S10
    i blew the line off due to me failing to get the new line clipped in right, the clip must have been 1/2 on, it lasted 8 hrs of snow plowing and it blew off blocks from home. i coasted home. whats funny is it never took 6 quarts to fill, more like 5 and 3/4, when the line came off the oil pan was dry, i did a filter, pulled the drain plug and it just dripped out a bit aka nothing. put 6 quarts in, fired it up and it was not on the stick. did a wtf looking for a leak, took 3 more to hit the full line. being the cooler line came off, the cooler had to be bone dry too.
    what kinda sucks is every oil change your re using 3 qts of old oil. thanks for that GM.
  10. #330 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    This made me laugh.
    Unless you blow the cooler line.
  11. #331 Re: Project LQ4 - Poor white S10
    with your modded set up that might be easier to do. i never gave it a thought, till that day.
  12. #332 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Well, with the bay all cleaned up, I decided it was time to address what little rust there was
    I've used Ospho in the past and really like it. Price is really good too. $14 for one quart, and it seems to last forever
    Here's the results a day later. Mmmm... Chemistry!
    Ready for a couple coats of satin black
  13. #333 Re: Project LQ4 - Poor white S10
    thats some bad ass product!
  14. #334 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    I love it. Have you used it before?
  15. #335 Re: Project LQ4 - Poor white S10
    i have not ever heard of it, but you can bet your ass i already googled it and am heading to ace to see if they have it. thats pretty amazing.
  16. #336 Re: Project LQ4 - Poor white S10
    Antioch, IL
    ospho is good ****, just about the best you can get.
    2009 Challenger SRT8
    Expert at being gay.
  17. #337 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Kind of a must have if you live in the rust belt and work with older vehicles.
    Quote Originally Posted by ItHurtz View Post
    I'm sure POR15 is great stuff also, but a quart of Ospho and a can of spray paint fits my budget a little better.
  18. #338 Re: Project LQ4 - Poor white S10
    Antioch, IL
    por15 can suck a dick in my book.
  19. #339 Re: Project LQ4 - Poor white S10
    Jan 2014
    AR
    Hot rodders seem to worship Ospho and SPI epoxy primer. I've never used either. As far as I know, anything with phosphoric acid does the trick. Looks like you ought to sand then reapply and sand again then paint. Hey for after paint are you familiar with cavity wax (Rust Fighter if 3M)? For inside the hydroformed section of the frame and anywhere else that isn't protected.
  20. #340 Re: Project LQ4 - Poor white S10
    Mar 2014
    Tucson
    Quote Originally Posted by idrivejunk View Post
    I probably could. Honestly though, I'm just going to call that good and hit it with some satin rattle paint. I totally respect and appreciate what you do, but I'm certain this project would never get done if I got too hung up on the visual stuff or tied to compete with the pro's. I'm forcing myself to focus on cleanliness and function. It will never be a visual stunner.
    I read a thread the other day of a guy doing a V8 swap on a first gen S10. Started out like mine, just a simple swap. Then one thing led to another... Powder coat this, chrome that. Braided stainless everything. Racing parts galore. Five years and $20k later, it's still just a rolling chassis. I just want to get this thing together and smoke some tires!
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
