Thread: Please someone help me no one can fix my car problem!
Results 1 to 20 of 22
  1. #1 Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    For the past month I've had a metallic snapping sound coming from the front left side of my car, it makes the noise when I'm stopped and then begin to accelerate, it also does it when I hit certain bumps, and i can really duplicate the noise if i rock the car left and right (this was really duplicates the noise. I replaced the struts cause I was told that seems to look like the only thing that's wrong with my car and that solved nothing. Please someone tell me if you have any idea what is causing this
  2. #2 Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
  3. #3 Re: Please someone help me no one can fix my car problem!
    Stop making more than 1 thread.
    It wont get you yours answers any quicker.
  4. #4 Re: Please someone help me no one can fix my car problem!
    You know I have this same issue except on the right side(passenger) of the car, and I was thinking maybe one of my strut mounts was broken.
  5. #5 Re: Please someone help me no one can fix my car problem!
    gardner,mass
    hows your engine and trans mount?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: Please someone help me no one can fix my car problem!
    Quote Originally Posted by Ginseng View Post
    This bet they need replacing
    04 Comp G.
  7. #7 Re: Please someone help me no one can fix my car problem!
    Well mine looked fine when I put the engine and trans in in May.
  8. #8 Re: Please someone help me no one can fix my car problem!
    Worth replacing especially for how cheap they are. You never know it could fix the issue your having.. The key part is that it occurs from a stop which usually indicates a bad mount somewhere.
    04 Comp G.
  9. #9 Re: Please someone help me no one can fix my car problem!
    Arizona
    Hopefully you did strut mounts as well the clunking is probably your sway Bar and relates bushings and end links
  10. #10 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    Yes i did the strut mounts as well
  11. #11 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    And it's not a clunk it kinda sounds like when you run over a pop can, that kind of snapping crunching noise is what happens
  12. #12 Re: Please someone help me no one can fix my car problem!
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Door moldings loose ? They are plastic though,
    1997 Red GTP 182000 miles stock
  13. #13 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    it also resembles the noise of snapping twigs and i don't believe that's it, its more towards the front of the car
  14. #14 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    I haven't looked at those mounts yet but I'm going to the mechanic again tomorrow so i will tell him to look at those as well
  15. #15 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    I haven't looked at those yet but that could be a possibility i will get the mechanic to check that tomorrow
  16. #16 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    Quote Originally Posted by slick2500 View Post
    I had my strut mounts replaced and it didnt fix it
  17. #17 Re: Please someone help me no one can fix my car problem!
    You can check these things yourself..without spending money on a mechanic. Jack the car up and remove the wheel and check for anything visibly broken like the sway bar, endlinks, mounts etc. ill take you 15 mins to do and can save you quite a bit.
    04 Comp G.
  18. #18 Re: Please someone help me no one can fix my car problem!
    gardner,mass
    Quote Originally Posted by jbyrne View Post
    Just hold down your brake while in drive and press throttleand try in reverse aswell you should hear knock
  19. #19 Re: Please someone help me no one can fix my car problem!
    Jan 2013
    ontario
    i have checked for anything broken and there doesnt appear to be anything.
    I will also give that a try and see what happens
  20. #20 Re: Please someone help me no one can fix my car problem!
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    sound like how mine did when my sway bar cracked got one off fle bay for cheap and its a solid now so it works great
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  1. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. problem and i'm not sure...
    By hyped in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-04-2011, 07:27 AM
  5. Yet another A/C problem
    By TexasFury in forum General Tech Discussion
    Last Post: 09-23-2009, 12:32 PM
