Thread: 2001 buick lesabre wont start occasionally?
Results 1 to 4 of 4
  1. #1 2001 buick lesabre wont start occasionally?
    SE Level Member natejames99gtp's Avatar
    st.cloud minnesota
    Bought my sister a 2001 Buick lesabre around xmas with 218k on it. it ran amazingly and about a week or two after we ran into a problem and havent had any luck with it. first acted up when we drove it about 5 miles and parked for lunch and then came out after about half hour and it would turn over but not fire, similar to a fuel pump, however after a few minutes of trying it fired right up and drove just fine with no codes. it has done this a few times and a couple times it will be driving down the road and kill however it will then start up either immediately or after a few minutes. However once it wouldnt start for two days? we have replaced the battery, i also had the ICM tested and we ran it 8 different times and none of which showed it fail in any way. other than this i looked over the vehicle and found one frayed wire going to a fuel injector so i replaced it however it is still stalling randomly. i was curious if anyone had had a similar problem with their 3.8 and if you had any suggestions to fix it, any suggestions would be greatly appreciated
    could it have something to do with the VATS? would getting a new key from a dealer help by chance?
  2. #2 Re: 2001 buick lesabre wont start occasionally?
    sounds like a crank sensor. and they rarely set a check engine light.
    if you have noticed the tach dropping to zero before it stalls when driving, its a crank sensor for sure.
  3. #3 Re: 2001 buick lesabre wont start occasionally?
    Aug 2011
    Kenosha
    I have also had a crank sensor go bad with those same symptoms.
  4. #4 Re: 2001 buick lesabre wont start occasionally?
    st.cloud minnesota
    oh thank you guys, i found the how to on here and am going to go give it a shot now
  1. Occasionally won't start.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:03 AM
  2. 92 buick Lesabre
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-02-2009, 05:15 PM
  3. 1994 Buick LeSabre exhaust
    By Need For Steve in forum GM H Body
    Last Post: 06-29-2009, 12:57 AM
